Jim Hancock
Old School Technician
The numbers represent on-off readings from the lines on the encoder disc interrupting the beam from the sensor emitter. The readings from the 2 sensors - grit and motor - are synchronized to control the motor speed, based on the commands received from the mainboard-servo board path. You will see similar behavior from the linear encoder for the printhead carriage by running the Linear Encoder test in the print menu in service mode. It will go up as the head carriage moves across the printer and back down as it returns home. The G-ENC CHECK test should show changing sequential numbers as it runs.
