Help with colors on logo
Locals Find!
I designed this logo for a client. They like it.
However, I designed it black and white and they want some colors added. I am at a total loss as to what colors. They haven't given me any direction.
Any suggestions?
The magnifying glass is not clip art. I drew it myself. Just so we are clear here.
signmeup
Do the lens ever so slightly greenish like glass, the handle brown. Text... whatever floats yer boat. Try dark green... it''ll go with the lens.
mikey-Oh
Put a white highlight on the opposite side of your magnifying glass and try the tag line/slogan in a complimentary colour
iSign
you could put a colorful bug in that dead space below the L..
then a colorful sunbeam could pass through the lens & have a little colorful fire torching the bug... what better to do with "dead space" :wink:
actually... I think a light gray shadow, transparent almost, might work, since the lens gives a 3D perception already anyway... also a subtle gradation in the lens may look more transparent
The Vector Doctor
Chief Bezier Manipulator
I know you are not asking for design help but I thought I would put in my 2 cents...
I am not liking the space below the Lo letters in local. Maybe the handle of the magnifying glass could become the "i" in find
I think the tagline is what is making this look odd. Without the tag the space does not bother me, but the tagline is acting like a container for the white space above it
Edit: Isign was thinking deadspace too as I was typing this
iSign
i mean I know this sounds corny & it's more of a logo revision then an addition of color... and a mag is not exactly a prism... but because of the "find" element...
a rainbow arcing down through the lens, widening as it goes... and illuminating a handful of gold coins (forget the cliche "pot")... but a small cluster of coins could look like the reward for "finding"... AND fill the dead space... ok, I told you it was corny :corndog:
mikey-Oh
I could, but stopped mocking stuff up for free when I was 17.
Lost an entire post for you, thanks Droid, but the gist of my suggestion was to learn true quote marks... if that's how you wanna differentiate the slogan
Locals Find!
Sorry, had to reboot. I am back now.
I tried your suggestion about killing the dead space. I pulled the tag line, and extended the magnifying glass.
Let me know how this looks to you guys.
iSign
doc's idea was worth trying, but in my opinion the handle looked better before. I don't like the purple either, but the glass looks better, and as doc said, without the tag the space might not matter so much. You thinking of leaving off the tag? so, no on the subtle shadow idea?
Locals Find!
Let me make sure I am understanding this.
1. Lose the purple
2. Keep the lighter green on the glass w/ white reflection
3. Lose the extended handle keep the "I" in Find the actual letter.
Was thinking the tag could be moved around as a separate element on actual marketing pieces. Posters, signs, etc...
Was quite sure how to pull off the subtle shadow. Its a technique I am going to have to learn. Any advice on where to research that?
iSign
like post 14, but green "Find" and the handle in 14 is good, but the lighter blueish glass & white highlight on glass from post 13.
for a shadow, copy all the letters, including the mag ring & handle, paste back, send to back, fill 5% bluish/black, and then push down and over enough to only see behind your letters on one angle, like a shadow.. it you have & can use transparency in your software, you could leave the fill color at 100% and use transparency
Locals Find!
I am using illustrator cs2 so I should be able to pull this off. Be back in a few with a new version to review.
Locals Find!
I made 2 versions. One with your suggestion of the shadow. I threw the tag line back in. I was thinking it sorts helps with figuring out what the name means.
The second version I extended the handle & handle shadow to try and fill in that dead space boxy area that occurs from the tag line.
