Bienvenue à Signs 101 de Winnipeg!
How are you sending down the job? (format, layout etc.)
Is this a bitmap image (like a photo) and if so what resolution is the image. ( Example 300 dpi 150 dpi etc. ) Are you making a file in a program where you place 50 of these images or are you just placing one image into your rip and then asking it to do 50 copies?
If you have 50 images in a file created and then you place that file to be printed in the rip, that can be a huge file. May be why it's taking so long.
Also how big is the decal?
So did this file work fine another time or is this the first time for this file?
You could break the runs up.
i.e. 1000 stickers in six runs.
It is working again !!
Ok please help !!
Tell me how can I asked it to do cut 120 pages of 50 stickers !!
PLEASE !!![]()
Ok please help !!
PLEASE !!![]()
What program are you using to export the eps?
Can you set up the 50 repeats in that program and then export that as 1 file, then set up the copies in VersaWorks to 120???
I think you are better to load that file and ask it to do 500 ( if your cutter will be accurate to cut that many) and then load the same file and do the same thing untill you have 12 files in the rip that will run after each other. This way you are cutting only 500 at a time and then starting over on the next 500 etc.
I would think if you tried to print too many before cutting the cuts may be off by the end of a large run.
