fivepoints
I asked this question the other day, but I didn't get no info that helped me and I know there are some very knowledgable people on here that know the answer or can set me straight. I'm flustered and don't know which way to turn as I thought I had run into most things in Corel during my years using it. Here is the problem. :Oops:
I am cutting vinyl out of Corel X5 to a Roland PC-600 and all of a sudden when I send it to cutter the whole roll will roll off and won't cut. BUT when I do a test plot the cutter does fine and I also tried cutting out of Flexi 8 and it cuts fine. I do most of the work out of Corel though and I know it has to be a simple setting change that somehow happened. Can someone give me a little help or have any ideas? The problem is not in the file as I have tried using different files and started new ones and it still just starts rolling off the vinyl and never starts cutting until I physically stop cutter from rolling it off. I am pretty sure that the problem is in Corel since Flexi and I can test cut on the cutter with no problems. Does anyone have any ideas![Thank You :thankyou: :thankyou:](https://signs101.com/images/smilies-orig/standard/thank you.gif)
