how do i cross cut automaticly?
i know theres got to be a setting to auto cross cut after every job right? i just can't figue out how, anybody know?
also i am using flexi 7.5 and can't figue it out there either.
woolly
its a option in the graphtec windows driver and i think in the controller so should be in flexy. er somewhere
woolly
chopper
if by cross cut you mean it will cut the sheet off the sheet at the end of the job...
that will be done in the software if you do not have a high enough version it will not work, ( I know that you have flexi) I have sign lab and it wasn't available till version 7.1 rev9 or 10 it will be an option in the cutter setup to auto cut after each job, I have it in sign lab 8 works great... you should ask for a demo of sign lab 8 the photo editing is worth the switch alone!!
//chopper
PMG
On my Fc 7000-130,to do a cross cut ...on the plotter its self hit menu / next /then choose cross cut.
PMG
Got yah..... here is your answer LOL in PM go to Graphtec properties .here is a pic,as you see i have mine turned off.Hope that helped:peace!::peace!:
PMG
after you open default job properties at the bottom there is a button called cutter options (see Pic below) open that up and go to after job.
PMG
In Production Manager (PM) Right click on your plotter and go to default properties .
