is all copy the same height?
If so you should make a jig out of scrap
sign materials. If the coro will be 1/4",
you will want tape a 1/4" x 13" x 2or3" pc of something that has a straight edge that all your pieces will rest against. This tapes down to your bench close to the front where you want to work.
Then some scraps about 4" x 4" at each end that will keep a 13"
sign from sliding around, but even though many of your
signs will be small... it has a more important purpose... holding up the 3rd scrap.
NOW the 3rd scrap will be at least a 15" long piece of something (clear plex has some advantages if you have scraps of that) that will get taped on top of the other pieces. Use double face foam tape to lift it up enough that your
sign blanks will easily fit under it.
This jig idea is most useful if all the
signs will have the same size lettering, because then they should all have the baseline at the same height up on the 6" coroplast blanks. So lets say you will have 3" lettering & you want it 1-5/8" up from the bottom of the
sign... you will tape the clear scrap so that the top of it is 1-5/8" up from the top of the first scrap below it. This way, all your signblanks can be quickly slipped under the clear scrap all the way down until they sit against the first scrap. That last thing to do to the jig is mark the center of the 13" space onto the clear scrap.
If you set up all your copy to be cut by center justifying it... you can mark a pencil line down through the center of all of them in no time at all.
If the various size blanks are still lumped into large groups of 13" ones... lots of 12" ones... & lots of each of the other sizes... you could do the 13's first, then tape down a couple small shims to modify your jig for each batch of different sized
signs. If there are too many different sizes, & not many of each... you could tape a ruler to your jig starting at the center & that would help set each
sign in there centered to the centerline mark on your clear scrap. (the clear is handy to see your descenders or your round letters dropping below the baseline, & to give you the best clear look at getting your base line just right.
So, you get all your copy cut apart without too much excess
paper around each one... & the centerlines marked on each of them. Then you have all your coro there & a masking tape dispenser... slap a
sign centered in the jig... grab 2 tabs of tape & the copy... slip the copy down under the clear scrap until the base line is aligned with the clear scrap & the centerline aligns with your mark, stick down 2 tabs of tape... & my method would be to set aside the taped up
sign & just keep doing this until you are lightning fast... if somebody else will help... they can squeegee down the copy... otherwise I would set them all up first... then squeegee them all down in another process that you will fly through because it is just the same motion with no distraction of changing between 2 process's on each
sign.
I hope that explanation is not too confusing. It is honestly a very quick process in any shop that has double face tape & scrap materials around already. On 113
signs, this jig can save you hours.
Not counting typing, cutting weeding or taping... I could apply 113
signs this way in about 30 seconds each or about 1 hour.
Even $5 each would be profitable... but I'd go with a sliding scale based on sizes & trying to price it so it averages a little higher then $5 ea, but less then $10
