How Much would this Fetch in you area?
R08
On oracal 3651 and top laminated. Both sides installed.
approx 2.5'x6 (near as I can tell) including birds.
I'm thinking around $275 - $300 installed.
I don't do a lot of boats. This guy is a small contractor and I get all his work.
Am I lowballing?
And critics invited to comment on design
Rob :Canada 2:
4R Graphics
I would be in the $360 -$420 installed if can reach from dock or wading out. That is based on basic prices no extra for boat and all the problems that comes with that. Also Im with the others I would use cast on a boat and the price would go up for materials I would be around $600+ for cast.
R08
You sure you want to use 3651 on a boat?
I've had very good results with calendered on boats in this area. We don't get a lot of hot weather.
This boat will not be seeing any salt water... if that makes a difference.
On the other hand using cast would not cost that much more i guess.
Rob
R08
they can afford a sail boat. :wink:[/quote]
Ya kinda thought that too.. I'm guilty of charging more at times when I know the guys got a lot of $$ :smile:
R08
This area has been financially depressed for while since the mining industry here took a dive.
Three other sign shops have closed up in the last 5 years.
If I push this much higher I will for sure not get this job.
But I do believe it's time for me to creep up though
This is the way I figure:
2.5'x6' @$10 ft2=$150 x 2sides = $300
Probably as much as I can get in this area.
(On the plus side... bought my house for $49k)
Rob
OldPaint
reason you charge more for sail boats.....MOST EXPECT YOU TO LETTER IT WHILE IN THE WATER.....and sial boats are the "CHEAPIE" bunch, since they get their propulshion for FREE....they dont like to pay for anything)))))this is how cheap they can be:
had a good freind who owned a sailboat went out in it a few times, but i was a fisherman at the time and seen it as a waste of good fishin time...tryin to make the boat go where you wanted it.)))))
he went and bought PAINT, BRUSHES (1shot & 3-4 QUILLS, close to $60.00)to let some kid letter his boat rather then PAY ME!!!!!!!!! turned out a shitty job also.....
Bradster941
Including dockage. That's why you see so many anchored up off shore.
Stick Boat owners are some of the cheapest people I've ever met.
JR's
$600. all day long, only hp vinyl, if it fails your going have to re do it in the water, you don't want color bleed from cheep vinyl. it looks good tho get what you have to get to make a living and stay in business
JR's
p.s you charge more for sale boats because if something gos south it costs more to fix a boat then a car or a sign
D
DARLAK
Guest
i say again, scaffold??????
one foot hangin off the top of a laddar (any size) for a graphic that small......
25 minutes tops for the install, drinking in the marina by 11:30......
i'd do it for about $400 CA$HHHHHH
