How to keep seams from separating over time
JulieS
We sometimes need to print signs in multiple pieces/panels (if they're larger than printer width). I do add an overlap of about 1/2", but have had the seams shrink, separate, curl over a couple of years. Any advice? Would vertical seams be less likely to do this than horizontal ones for some reason? Would it help to wait longer before laminating?
Thank you!
do you offset the laminate seam from the printed substrate seam?
IF I WERE HAVING AN ISSUE with this sort of thing i would consider trying one of those 3m primers you use to keep edges from lifting up
  • Informative
unclebun
It really depends on the life of the material you are using. If you are using calendared material, it is going to shrink and there's not much you can do. In the sun, it dies in 2-3 years.
  • Informative
Reactions: 3 users
2B
What material are you using?
What printer are you using?
Are you doing an interior or exterior installation?
Reactions: 1 users
rydods
Member for quite some time.
Sounds like a material issue as well as possibly the location you live adding to the lack of longevity. Post heat these seams to the material manufacture's specs as well.
  • Informative
Foremander
Couple things that helped us. On solvent prints we let them gas out at least 24 hours before laminating, longer if the ink was heavy. Lam them too soon and the solvent trapped underneath softens things up, and you get exactly that shrink and curl at the edges a year or two in.
Then which way the overlap goes. On a horizontal seam put the top panel over the bottom one like shingles, so water runs off the seam instead of into it. Vertical seams don't hold water, so they usually last better. I'd go vertical when the layout lets you.
I'd also bump the overlap to about an inch, wipe the overlap with alcohol before the top panel goes on, and post heat the seam. And like unclebun said, if it's calendared it's going to shrink no matter what, so for anything outside more than a couple years go cast print vinyl with a matching cast lam.
  • Informative
Reactions: 2 users
DL Signs
Never go against the family
Just like doing vehicle/ trailer wraps, use cast vinyl with cast lams so they don't shrink. If it's color to the edges make sure to let the ink cure completely before laminating or you're inviting edge shrinkage from the inks to, and always post heat to set the adhesive, paying special attention to overlaps.
Hint: If you really want something that won't let go, for large multi panel permanent signage I reach for the 3M IJ-175, once it's laid and heat treated, it's not coming back off... Ever... Seriously... It's a 10 year air release cast, conformable, I use it on most exterior signs, and it holds up in central Wisconsin where temps range from 100 above in summer to over 40 below zero in winter.
  • Informative
Reactions: 1 users
Stacey K
I like making signs
I always used vertical seams. I've always used calendared with cast laminate and I have not had any issues but I think every combination of print/material is a little different. When I first started I used Signs365 IJ35 with their laminate which I believe is cast? 8 years later all those signs still look great, even the paneled ones.
  • Informative
Boudica
I believe the rule of thumb is that you can use cast laminate with calendared vinyl, but you cannot use calendared laminate with cast vinyl. The cal lam will shrink but the cast vinyl won't ...and it's not going to go well.
We always do a 1" overlap with seams, vertical is usually best, though we have has some occasions where we need to do horizontal seams.
ps... IJ35 is a calendared vinyl :)
Reactions: 1 users
Stacey K
I like making signs
Another thing with ACM, you can't really trim right up to the edge because the edges lift. I always have trimmed them a little bit in, but then you have a white edge. Most signs it doesn't matter. On the signs you might see close up, you can either wrap the print around the panel to the back like an 1" or you can trim the edge about 1/4" then add a 1" strip of the same color print and wrap it around. I just did that last week with a red sign because it's literally on the street corner and I didn't want that tiny white edge to be seen or people to pick at it since it's a tavern.
Stacey K
I like making signs
Correct that vinyl is calendared, I think the laminate they use with the IJ35 is cast but I haven't ordered it for a long time so I'm not sure...I thought I called them once and asked, but I can't remember LOL
guillermo
all the advises are great.... however, I got some curling after a few months, this is for installed panel with a vertical overlap, I noticed the same when mounting laminated adhesive vinyl to dibond or rigid substrates, my problem was with the lamination, I had too much tension when laminating, stretching the lam and overtime, it will shrink. after noticing that, I started to have the lamination roll loose and that problem stopped.
