How to Laminate Gold Engine Turn Overlaid on Black
hhg98
Hi All,
This truck was in our shop and I have no idea how their decals were done. I should've grabbed a photo before it left, but they had gold engine turn overlaid on black and the two layers were laminated together but the laminate was bigger by about 1/4 inch so it sealed the edges completely. We work with a lot of overlays and specialty materials so I'd love to know how to do this. I'm sure it increases the longevity of specialty vinyl. I know we can laminate layered graphics together but I didn't understand how they got a 1/4 inch bleed on whatever clear material they used as laminate. Any ideas? Again, sorry I don't have a photo. I might be able to get one later.
Billct2
We do this on all RealGold truck lettering. Apply clear cast vinyl with an extra 1/8" or so trap. We Edge print the black but the technique is the same for layer lettering.
It can be done prior to install on the roll but it's much easier to do on the substrate
hhg98
What kind of clear cast vinyl do you use? Do you throw it on a plotter and have it cut to shape and then lay it over top of the graphic?
Yep. We just use 'offset path' in illy and it's a go. Normally a good cast laminate
kcollinsdesign
Old member
Signgold (Real Gold, Quick Gold, whatever it's called) is 22k gold sputtered onto vinyl and comes with a laminate already on it. I see no real reason to laminate it unless it is subject to excessive abuse (fire engines come to mind). If I stick it on cast vinyl (for black outlines, for example) I don't do anything to it. If I stick out on a substrate (like a painted surface), the I edge seal it with ONE SHOT 4005 UV blocker acrylic clear (test first, this can damage paint). Convenient pens are available (they are loaded with the same stuff) but I find a small quill works better. I think laminating the whole Signgold graphic with clear vinyl would shorten its life (the laminate would start to fail before the Tedlar laminate on the Signgold). I almost never laminate or clear real gold leaf.
Laminating or clearing SignGold (or real gold leaf) changes its refractive index (real gold just reflects). It doesn't look like real gold anymore (to me). Of course, most people won't notice or care.
ProSignTN
Fire Engines are by far the most protected graphics of all the vehicles we have ever lettered. They stay inside a nice climate controlled bay ninety percent of the time and get washed on a very regular basis.
  • Agree
Reactions: 1 user
hhg98
Gotcha. Thanks for the insight!
Eric H
Pierce fire equipment also does real gold leaf between layers of vinyl. If the engine turning follows the lettering there's a good chance that's what it is.
To me, this is a yes, but not really... kinda answer. While they are protected from the weather for the most part, how many other vehicles when working are many times so close to fires, chemicals and other abrasive things ?? Plus, like mentioned..... these fire-guys are meticulous about their trucks and are forever cleaning them.
hhg98
It seems like opinions are really divided. I just wanted to know how it was done... I still don't know what kind of cast vinyl would be fine to use because I am interested in protecting the gold material, regardless of it is already coated or not.
signheremd
Use Cast UV Laminate and plot the lettering out larger than the Sign Gold. Note: Sign Golds says you should edge seal it, so I think the issue isn't the material but to protect the adhesive and edges from wear.
  • Agree
Reactions: 1 user
It's been explained to you several times and we almost all have the same answer. There's no division going on. My only yes/no thing was the need for lamination on the merits of it not being exposed to weather all that much.
You're only doing this maybe a year, so laminate it and let your shop guy put it on.
Okay, I get it now, also. I have no clue as to your last few posts, so suffice it to say, YOU know what you're doing now. Right ??
saltybum
20+ years ago I started using a lot of the SignGold/Real Gold and originally it was recommended to seal the edges. Can't remember what year it was but Bill Crowley (one of the owners) told me they improved their adhesives and edge sealing was no longer needed. I've lettered over a 1000 boats with quite a few being with gold vinyl material. "Just Pullin" was about 12yrs old when I took this shot. No edge sealing. At 14yrs it was showing more cracking but you had to get close to it to see it. Most all my boat jobs were saltwater boats and in the harsh Florida sun year round andnever had a customer complaint about peeling.
Mike Paul
Super Active Member
I use SignGold on trucks and have edge sealed it with a quill but usually just do a small inline on the letters, delete the origin
Mike Paul
Super Active Member
Then outline the same thickness with a radius. If there’s a spot I’m questioning I’ll put a small dot of clear on it.
jfiscus
Rap Master
Fortunately, it is no longer required on all major manufacturers' Gold vinyls. It used to be required when we used a lot of Leo's Gold Lion products.
We use the Gerber Edge & plotter system to generate the print-weed-laminate-weed process' registration between the layers.
