I don't do much of this crap......
Shovelhead
here's the breakdown......
guy's got a tanneau cover on an S10 (gelcoat...no clearcoat) that was striped
to match the factory striping..... 28" or so wide with 1/4" accent striping on either side...you know what I mean.....
existing vinyl is probably A4(Metallic Silver) although it's not very thick.......there's no shrinkage...just spidering.....but it's really messed up for being on for two years. He wants me to remove it and replace.
The no clearcoat thing scares me and the vinyl probably won't just peel with heat. I removed vinyl from a van last week were the customer was aware that it was A4 Metallic Gold when I applied it....after two years, removal was a nightmare....instead of peeling, it flaked off with a heat gun.
Question is....do I even attempt it with a Lil Chisel on the gelcoat?
Second, how much for this job.... 28" x 84" HP metallic silver with removal.
:wine-smi:
Craig Sjoquist
is the customer willing .....1...by the hour
.....2....no guarentees
....3 repaint and clear coat
...assume it's a DARK color, with silver stripes, which very well be the reason for spiderwebbing......in which paint will be the only true way of solving, and happening again
....4... is the truck worth it to the customer, for cost ... lets say it takes a full day maybe plus to remove, clean up and touch up ,,ready for stripe or with ????
13 folds
SignosaurusRex
Yuk! Metallic Avery.....We did a removal of Old Metallic Avery with a "Zapper" on a dozen PD cars. Worked great. We've never had an issue on Gelcoat.
Mike Paul
Super Active Member
Charge by the hour for vinyl removal so you don't lose your shirt. Sometimes it comes off easy and sometimes it's a nightmare. $75-$100 an hour is about right. Don't forget these additional costs... rags, adhesive remover, alcohol etc.
B Snyder
What Mike Paul said. Its certainly could be A7 cast metallic silver. No metallic vinyl is going to hold up very long when exposed directly to the sun on top of a vehicle especially if its on dark colored paint.
TLG
I just stripped 2 large and 2 smaller metallic silver panels off of a black single axle trailer. I applied the 2mil about 2 years ago. It was 5 1/2 hours of HELL! Ran my 1800 watt hair dryer, used a Lil Chisler and the plastic razor blades from Fellers. The vinyl came off in 1" chunks and left all of the adhesive. That required more than a full quart of remover and a LOT of elbow grease.
Don't ever want that type of job again :>(
kalvix
any chance this is a west coast cycles truck upgrade package? they used 3m automotive grade vinyl. we redid 4 for a local dealer because they 15k upgraded trucks wouldn't sell with the spidering on the vinyl... we used an eraser it was a nightmare but it came off...
vid
MBX Vinyl Zapper???
MBX Vinyl Zapper!!! ...and CA is closer than OZ. No XXXX beer, though.
We had used a wheel that fit on the end of a drill. I thought it was called a "vinyl eraser," but I couldn't find it in a quick search. The red one sucked but the white one worked fine. I think they were $39-$49... you might need 2.
They will burn paint (don't ask me how I know)... and you need to unscrew them off the post and filp them around every once in a while to keep them somewhat true.
Good Luck!
onesource
run a razor blade between the vinyl and glue. I swipe the blade on some glass a few times to dull it a little then slide it at as low of an angle as I can hold it. It takes a little getting used to but works well
chopper
the gel coat is better than clear coat any day way tougher, I would try a pressure washer to remove the old vinyl, use a little orange peal or something like that and wash it off, I have used a soap that has removed all kinds of stuff
the drum is over in the other shop so I dont have the name of it handy
good luck //chopper
grafxxx
good luck with that i had a customer with that exact same thing told me the vinyl was just on for a year took me 6 hours 2 cans of 3m adhesive remover and heat gun all 3 chizlers. ugggghhhhh. never again.
Shovelhead
Thanks everyone....
my main concern was the gelcoat.
I've attached some pics that I failed to upload yesterday.
I will be replacing the tanneau stripes only. Conservatively, I figure (5) hours to
remove, cut, weed, tape and apply.
I can't hit the guy with more than $375 for a side job after hours.
:help:
chopper
with a black gellcoat there shouldnt be ghosting, as in fading you may see that there are more scratches in the surrounding area from washing and a little buff may be required, but as usual you never really know till the old stuff comes off, but if you are putting the new stripes where the old ones are who will know?//chopper
