Ok i bought my plotter/cutter of a guy. it has VE LXI Master+ software loaded. its vinyl express machine. when i turn the machine on it says Jaguar III. So Thats my knowledge. Since then with setting:
Com port 1
BPS: 9600
Data Bits: 8
Parity: NONE
STOPS BITS 1
Flow COntrol: I tried hardware and Xon/Xoff (i made sure under devise manager that they matched).
I have it set on GRC-61. When i cut my design measure it up then send on the masters+ it says cutting 0% then after while says write port error.
only other thing i can know is on setup properties it says the name is under Jaguar JG-76S.
Any help appreciated. please explain it like you would to an idoit. thanks
Com port 1
BPS: 9600
Data Bits: 8
Parity: NONE
STOPS BITS 1
