I currently own and use a PNC-1100 for over 15 years. Instead of trying to use my PNC-1100 with Win11 Pro 32-bit, I simply kept my old Laptop that is setup for WinXP and Win7 OSs and with a docking station using a Parallel Port.
With this proven and working setup I continue to avoid having to switch to OS 64bit s/w and Printer Drivers, worry about 32bit Printer Driver compatibility, having to convert parallel to serial to USB Converters and s/w Drivers, etc.
The Roland DG PNC-1000 Series Service Manual can be found using an Internet Search for testing if needed.
The main maintenance problem I see with older PNC-1000s is the internal guide wires roller bearings jam with dried grease that slows the printer cartridge side to side movement and throw the hardware timing of printer carriage movement off time to correctly match the printer software timing. The result is the printer software driver does not known the printer hardware is working too slow and ends up confusing the printer hardware with software commands it cant respond nor buffer.
When I first bought my used PNC-1100 over 15 years ago on eBay, I paid for shipping from the Seller's USA location to the Roland DG USA to check and renew the mechanics of the PNC-1100. At that time, I heard a slight concern from Roland DG Tech Support that the main problem with the PNC-1000 series (including my PNC-1100) were roller bearings used to guide steel wires and the printer's carriage movement would slow and start to jam with dried "axle" grease within the roller bearings cage. With the older technology when time the PNC-1000 series was last manufactured, sealed bearings and lithium grease were too expensive and unavailable for Roland DG to include in the PNC-1000 series of Cutter/Printers.
I paid Roland DG Tech Support to clean and re-grease the roller bearings axle grease with Lithium grease and I have never had any problems since I received my eBay purchase many years ago.
Roland DG no longer offers this repair service service for PNC-1000 printers/cutters because these models were discontinued by Roland DG decades ago and are no longer supported. PNC-1000 self-repair by users is difficult because the the internal guide wires have to tuned to specific wire tensions to operate properly and most people do not have the equipment to accurately test wire tension values...
