Over a few cokes a friend and I were discussing this very fact. I suggested without light a printed black or dark blue would look the same.
His response was on his monitor in the dark colors looked much better. Who’s right and who’s wrong? Or are we both right?
They're unrelated; no light, no color, since color is merely light reflected (not absorbed) off an object.
The colors looking better on a monitor is subjective, and also different than reflected light. So monitors and printed materials are going to look different no matter what. "Better" is an option.
My $0.02,
Jim
Without light, there would be no color. Color is merely a reflection.
Now as to colors looking good on a monitor.... your monitor is EMITTING light, from the inside out, has nothing to do with it.
Hi SJM,
Sorry, I meant to say "Better is an opinion." (option was a typo)
Also, while there's a relationship between CMY annd RGB, they're not interchageable. RGB has a much broader gamut, and emitted light (monitor) is different than reflected (printed). With LCD montors it's even worse than the CRT monitors of olde, since LCDs are unnaturally bright, and change with slight variations in viewing angle.
And depending on the contrast ratio of the LCD monitor, seeing differences in shades can vary widely as well. Trusting what you see on-screen, is dicey, at best.
IMO,
Jim
If you print blue in the dark...what color is it?
I think recognizing those advantages means less trial and error and ultimately adds to the bottom line.
Yes, you just can't see it.Is there color without light?
Same color; just no light to reflect it.
Same with a tree falling in the forest. It makes sound waves regardless of whether they reach a human ear drum.
Jim
Physics isn't your long suit, eh? Color IS light. No light, no color. That is why something is different colors under light of different spectra. It's not that it appears to be that color, it IS that color.
If you paint your bedroom blue, what color are the walls when you turn out the lights? They're still blue walls; the light-reflecting properties do not change. The light can change. But the walls are the constant.
Jimbo![]()
