I am new to this and I need a little help. I have been using calendar vinyl and it has been cutting fine. I just bought some cast vinyl and everytime I cut it is lifts up on the corners ever so slightly also the edge has a very very fine jagged look. I have replaced the blade, reset the pressure to 60 and slowed the machine to as slow as it will cut. I have a 24in cutter and the cast material is only 6 inches wide. I only need narrow width vinyl because the bulk of what I do is car tags. Can anyone give me some advice on what else to try. Thank you
