Just Can't Catch a Break...
JBurton
Signtologist
That's the most disingenuous thing I've heard in a long time. Maybe I can use this argument when dealing with permits. It's not advertising anything, this is just a tip for anybody driving past this mcdonalds...
  • Hilarious!
  • Agree
Reactions: 5 users
Pauly
Printrade.com.au
Microsoft will cause the death of itself with all these add injections into everything.
Every day there's something new i disslike about windows.
The only issue for me is there is a few apps i still rely on which dont run linux - Adobe is one.
More and more people leaving windows for Linux or giving it ago and realise "It just works"
WildWestDesigns
I've been a user of Linux for just about 20 yrs (18 actually). What I would suggest, is not thinking about can it run program X, but can it do function Y. What functionality do you need from the adobe program(s) that you are using and can the alternatives do that to the level that you can still get the job done. There are quite a few alternatives for Adobe and with the web being used more and more (shoot even Adobe programs have bundled Chromium in their programs), cross platform is less of a concern. About the only good thing that has come out of the modern web, I have even used it for just the UI portion of my C/C++ tooling, but all still local. The one thing that won't be able to be replicated is how seamless one can use each individual Adobe program with another one. That was always the thing that I had liked about Adobe since having been a user since the early 90s. That has gotten better on the Linux side, but still not at that level.
When I switched, my hold back program was an embroidery digitizing program. Only on Windows, no Mac version, their recommendation was a VM and we are talking $15k for one program, not a suite. It took awhile, but no need now, got something that does everything that I need (including some rare functionality as well that most don't need, but I would). While there is always WINE (Mac has a commercial variant of that same program, which can happen in OSS, nothing in the licensing prevents that) and I had heard that got better running Adobe programs, there isn't going to be the ability to run it directly and probably never well. It never worked great for those that had to deal with dongles either (like aforementioned digitizing program). DRAW was the only one that had a Linux variant for time and I highly doubt outside of Substance Painter, Adobe will do this.
Pauly
Printrade.com.au
For most people, replacing adobe is easy.
For users like me, it can be challenging.
E.g Acrobat pro.
We use Enfocus Switch, Griffin, Pitstop Pro and Server. that runs on Windows Server.
Griffin desktop runs on win and mac, so does Pitstop Pro.
Pitstop pro needs Acrobat which is a plugin.
Griffin is a GUI nesting software which helps us create our automations for nesting.
We use the GUI to get the output we need then we get the config into Switch automations.
Quite frustrating.
I will eventually move those to a VM, they're not daily used.
Windows server is at least not full of bloat and bs apps. so its manageable.
I do have and use Linux alternatives for a few things, but they're all self hosted in docker so all web apps.
WildWestDesigns
E.g Acrobat pro.
Quite frustrating.
All of those are related to each other, I think all of those apps you mentioned are Enfocus apps and most are centered around Acrobat workflows.
Maybe a rough commercial alternatives that would be for Linux would be Apryse, OSS would be Apache Airflow. Not exact, but those would be the closest that I would figure on.
I despise Docker, I really do. Put Golang (I like it OK, it has it's perks) on the map, but I just don't like running things in that type of environment. Docker can be used for both native and web apps though. Some use it as a means for cross compilation.
Pauly
Printrade.com.au
They're all enfocus apps, Yes. to Design PDF workflows Pitstop pro need to be ran in Acrobat with a plugin to see results.
We are building something where Switch might go and maybe pitstop (replaced with something else) but still need griffin (windows/mac)
I really like docker, took be time to get around it but i love it.
Run apps in its own env, or stacks. I have nightly backups and if something happens i can very easily restore any container. I use a lot of webapps so access anywhere on any computer is great.
Personally, I hope windows dies. most good apps work on linus anyway. gaming community showing more support. More and more linux alternative apps are showing up, the Self hosted apps (docker) are pretty wild for those who want to host and especially for businesses.
WildWestDesigns
I don't think it will ever die. Maybe for the end users like us it may, but their biggest customer(s) are big business. Even some end users won't change because Windows is what they know (I'm old enough to remember when MS had a Unix-like OS), to me, it peaked with Win 98. It was at it's most powerful (for end user mucking about, not necessarily computational power) and the UI got out of the way.
About the biggest boon of Electron (or just using the frontend for a GUI stack even for otherwise local apps) is that most browsers are cross platform to begin with. For some things, I'll use the web for a gui for my C/C++ apps, run it as a desktop app or have it able to also be broadcast over the LAN so any computer that's connected can also use it app as long as it's open and running from at least one computer. Unlike Electron, the app takes up about 1-5MB (depending on what all assets are bundled in) and that is even statically linking to musl, fully static binary (just a sys call to the browser/webview to run a minified/app instance). I just cry a little seeing that RAM usage go up. I can handle it when it comes to non trivial apps, even apps that don't use the browser context, even for just the GUI can take up the same or more resources.
Ironically most game engines always had a Linux export. It was mainly kernel level anticheat (which is a horrible thing, but I digress). I've gotten more into homebrew for retro consoles (GB/NES, wrote a couple for game jams, that will actually run on original hardware or on something like the pocket), so I actually tend to focus on that. I prefer the indie homebrew scene.
WildWestDesigns
O&O shut up is a great software for the annoyances of windows.. At the end of the day windows is windows but this does make it better.
Some huge problems with this, at least from my perspective.
First and foremost, there shouldn't be a need for something like this. While the average user wouldn't probably ever go beyond what is easily accessible in the usual GUI places (given current generation abilities with computers and the fear that they have with even the CLI), the options should still be there for those that are motivated to harden their system(s) as they choose.
When I see programs like this what are they using to aid in this (for instance, if they use as part of it, the host file, well MS has largely been ignoring those entries since the shut up win 10 upgrade days) helps to if they are OSS especially considering that they are doing some system level changes I would prefer to be able to vet it, does it strip anything out (running the risk of castrating functionality due to how everything is tied to one another) or does it just make changes that can be changed on the next update and have to be reapplied and if they still work and the update didn't change how they were handled. Also, if they aren't stripping out, it would seem to be only doing things that an individual could do, so while time consuming initially, it would honestly be better for the end user to be more familiar with their system and not rely on a 3rd party tool. I understand the convenience factor, ironically talking about security concerns, convenience and security rarely, if at all, go together. Security isn't really something that we should be delegating to others for every little thing (in some cases yes, but a lot of people delegate everything to someone else and that's were it gets hinky), we have seen too many breaches (and those are just the ones that we know about, imagine how many are still under wraps), no one is going to care about as much as the person that is directly affected.
The above software could still be very good and worth using for those that are still on Windows (I haven't been since Win 7 was new), these are just some things (and more) that I would look at if I'm trying to vet something for security.
Boudica
It’s great to see members supporting the site and appreciating the work that goes on behind the scenes. Maintaining an active community requires time and effort, so the support from upgraded members really helps keep everything running.
People involved in creative work may also find professional embroidery digitizing services useful when they need to convert artwork into embroidery-ready files. Crystal Digitizing provides services for preparing designs for machine embroidery.
Thank you to everyone who continues to support the community and help keep it active.
Did you post to the wrong thread?
No it won't, people just become immune and barely notice them any more. (Unless its a nude Sidney Sweeney) They clicks still get their 3 cents each
WildWestDesigns
Windows has never really been "good", MS just had "better" versions here and there(Kildall (and CP/M) was done dirty). While I liked Win98 (I still remember when they had a UNIX-like OS, Xenix), it was because of 3rd party vendors that it was actually tolerable. Problem is now, 3rd party vendors are just about as bad as Windows. To add insult to injury, most people today really only know the high level abstraction (and this is a problem in other areas as well) that is modern day Windows and can't easily migrate to another system that may not be as abstracted (although it is unfortunately getting that way).
Gene@mpls
I attended Wadena County Vocational School in 1965-6-7. We trained on electronics repair and troubleshooting etc. We had a computer [tubes] on a 4x8 sheet of plywood and the instructor would introduce bad tubes or other components- you could not touch the board, you had to find it by writing a program to troubleshoot. I immediately fell in love with computers and tech. I took a year of programing [foretran, bitran?] and then my life spun off into building hand controllers and peripherals for the LEM module that settled on the moon. MS is one of the minor problems I have had with computers. Some OSs are better some worse of course- and now it is getting crazy of course with everyone trying to wring a dollar out of who ever might present. Tech school was free, I could have gone to College but am happy I made the choices I have, so far. One of our instructors was Mr Kern who started Kern Laser.
WildWestDesigns
In some ways it was easier back in those days, probably until the mid 80s when things starting getting even far more proprietary(I still remember "Don't copy that floppy."). Both in terms of hardware and software. Shoot, even end users could get the full schematic of what their system needed and what part #s to replace the OEM with. Shoot homebrew ASM programming for the Ricoh 2A03 and/or Sharp LR35902 is a joy compared to dealing with even the more high level abstractions that one must deal with when using Windows (even how they handle development libs is a pain compared to other systems).
Unfortunately, we have gotten so dependent on computers that what we use to interface with them is very important(the OS, not just the hardware input devices). Although I think it's mind numbingly bad we have appliances and even our vehicles are running full operating systems with WAN connections (especially with the WAN connections), but it is kinda cool that a blender can run DOOM. How the OS handles all that stuff is big thing. Therac-25 was bad enough, but at least it didn't have WAN connections. The more sophisticated "embedded" devices that are along the lines of the Therac, do run stripped down OSs that do allow for WAN connections(I would have less of a problem if they were at worse LAN connections and isolated from terminals that had WAN, but that's a pipe dream).
Johnny Best
I remember going to 7-11 to test the tubes from the TV to check if it was good or not. Graduated from high school in 66. The vocational school was Future Farmers.
