genericname
Doing some routine maintenance, I reinstalled some hardware on the JV3 after cleaning around the heads, and my hand every so lightly bumped up against the wiring for the voltage selector, located on the underside of the machine, at the far left side. These are the selectors that allow you to switch between a 220V and 110V source.
Anyway, I guess one of connectors was fatigued, as the brown wire on the selector closest to the front, on the left, just came off its seat without warning. Broken right at the base of the selector's plastic, I had to dig a bit to get the broken metallic lead out, and I'll be bringing my soldering stuff in tomorrow to see if I can replace it.
If replacing it doesn't work out, I know I can bypass the switch altogether and just short the proper wires together, since I'll never be switching from 110V to 220V anyway. Problem is, I have no idea which coloured wires I'm suppose to short.
Anyone have any clue? I know White is neutral, so that's in the equation no matter what, but that still leaves Black, Brown, and Red.
