mahgninnuc1
I recently purchased a used JV3-130SPii and am trying to work out some issues it has. It has a real nasty over spray issue on cyan.
The Cyan head does not appear to be clogged.
I have switched the cyan and magenta dampers around and problem stays with the head, i.e. the magenta is now over spraying.
I switched the ribbon cables between the 2nd and 3rd head and to eliminate the slider board being the issue. Problem stays with the head.
I started going through the Alignment process. Head adjust first.
The Cyan is actually completely encompassing the Black line.
I moved to Slant adjustment to see what it looked like.
Am I correct in saying it looks as though everything needs slant adjustment, but the Cyan looks completely jacked up.
Does the Cyan look as if it could be corrected by soaking the head, or is a head replacement in order?
