GettysburgSigns
Normally, after Turning the machine OFF, my JV3 130SPII would stay off for a good while, and then "Wake Up" and go through what I will call a "Cycle".
Recently, it goes through the "Cycling", and REMAINS ON.
Fans Run; Checks Its Inks; Fails to Go Back to Sleep!
If there is still Media in the Printer, it will ask the standard, "Roll" or "Sheet" ^<>, etc., otherwise it just says "Function...", and then it Remains Running - Fans-A-Blazing.
As this happens, the Power Button Glows Green, as if the JV3 is actually "ON", although the Button is NOT Depressed.
It will "ACT" as if it is On - It will Measure the Length of the Roll; Go from Function to Remote; Cycle, etc.
BUT, if I attempt to send a Print File to it in this "Zombie Stage" (neither dead nor alive), the RasterLink Program tells me that there is "No Communication... ", or something similar.
Technically, it sees that the JV3 is not Really ON.
At this point, I need to PUSH the ALREADY GREEN GLOWING Power Button IN, so the Program can actually find the JV3.
Please help me figure this out!
Thanks,
Gene / Gettysburg Signs
Thanks,
