JV33 dampers / cap tops
odshawaii
How often do you guys/gals replace your dampers and cap tops?
Do you replace only when you notice a print issue? Or replace annually (preventive maintenance)?
inkmed
it depends on your print quantity, as normal, when the printing is irregular or there are any leaks of ink system.
the damper or cap top need changed.
Adam Yang from Inkmed
SightLine
Cap top - when I suspect an issue. As a rule I change the dampers annually.
ironchef
My two magenta dampers are getting replaced as i type this. Im kinda enjoying this down time, they are also replacing the print head and capping station.
ironchef
Bump
