I cannot get a laminate on perf that I can see through. I've tried Valspar spray from Lowes, Superfrog frog juice, lamex 2 mil optically clear premium cast PVC gloss cold laminate, and two other lams we have in house. Nothing is working and it's driving me crazy.
oracal 291 is optically clear, use it all the time
are you laminating too soon and it is picking up the ink in the holes?
yup, you have to use an optically clear laminate and it is very pricey!!
Whoa...whoa...Valspar spray, that you can't see through? You aren't spraying it on the perf AFTER you install it on the window are you? If so...that's your problem.
Other than that...you should be able to see through the perf after installed.
Or am I missing something?
Spraying before install, letting it sit for 2 hours, still cloudy :/
I'm spraying the perf while it is still on the paper backing. The idea is fill in the holes to prevent moisture and dirt build up in the holes correct?How can a sprayed clear on perf be hard to see through?
If its a spray then it would not be in the holes once applied. In other words nothing but open air in the holes is hard to see through???![]()
Again - Don't laminate perf, unless the laws of your state require it.
