Large Install Pattern Material?
DChorbowski
Pixel Pusher
Heynow,
What are other people using for large installation patterns for chan letters?
My company has been using Tyvek and running it through our Sieko Colorpainter 104. We have found that on larger patterns, ones in excess of 40 feet, are not accurate. First we thought it was a printer calibration issue, but it turns out the Tyvek stretches pretty easily.
We used to use paper, but large patterns made from paper have their own issues such as ripping and water damage. We may have to go back to paper, but we dont want to if there is a better option.
Try backing paper from your 48" and 60" rolls. That's what we've used for years.
MikePro
paper patterns through the plotter... mounted to coroplast/cardboard sheets (whatever is handy).
we re-use the cardboard/coroplast for future patterns. holes in the material doesn't matter, as you'll end up putting a new sheet of paper over the top anyways.
SignManiac
We use our flatbed and print the pattern on 4x8 cardboard slipsheets it stays nice and rigid
+1 same here, but...was having issues with taping to stucco walls, until we just discovered they make a brand of duct tape just for stucco and it worked great!
J Hill Designs
When I use a rigid template, I just mount it to the wall with screws in a few of the holes that need to be drilled out anyway, or just behind a letter - I'm not confident with duct tape holding up a rigid template
FS-Keith
Same here, Saves lots of time in the field and great in high wind weather conditions.
