Large Sign Price Help
This will be my first large scale sign project now that im independent. The Assignment is that I must make a large sign, for 5 bussiness' in a hard to find location of a major rd. It also need to be within their budget, electrical is out of the question as well as any fancy masonrey. So here is what i came up with
My plan is to build a 3" x 3" 1/8" steel square tube frame that will hold 5-18" x 60" .080 alum panles on each side. I will be installed 30" deep into the ground. The total height of the sign is 15' (including in the ground) 5' above ground and 7'-6" of sign, witch makes it stand 12'-6" above the ground. I figure i will have about 90' of avery a6 vinyl in the job (assorted colors). Nearly 2 sheets of 5' x 10' alum, and two 24' sticks of 3"x3" 1/8" steel and another 20' of smaller tubing for bracing in the center, I will have apx $300 in steel. and another $350 in alum.
Now for the labor. Im figuiring about 4 hours to cut,weed,mask,and lay the vinyl on the 10-18" x 60" panels. about 20min each(they all have two color logos). Im figuring about 3 hours to cut, build, weld, and paint the frame, and another 2 to get all the panels on the frame and load it up for install. (Up to 9 hours). I will have 45min of travel time (if i dont hit traffic), and i will estimate another 1-1/2 to 2 for install between two men. Im thinking i will have about 12 hours max in the job. Does Anyone know where i should be at with price, i have a figure but i just want to make sure its not too high, he is a good customer, and i dont want to over charge him. Ive got a good system down for my smaller signs, but this one isnt you cookie cutter sign job. Thanks, Roger
D
DARLAK
Guest
WOW....
30" in the ground.....
12 hrs max??
not too high because he is a good customer???
this project is more than you can handle, walk away from it. from your description, you don't have enough experience with this type of sign, it is going to come back and bite you in the ass or fall over, which ever comes first....
iSign
nope.. it ain't cookie cutter, that's for sure. Whatever you charge, if he accepts it, then you didn't overcharge him...
so now that we got worring about himout of the way, lets worry about undercharging...
take those time estimates for example... sounds like they are fudged on the side of fear of overcharging at every turn...
myself, I'd say double them.
You are using different materials & methods then I am familiar with, so I can't say as much about suitability of those choices... but I'd say the job should sell for over $3K anywhere, (over $4K even)
30" in the ground, yeah thats right, its a lot of height on the sign, i'd rather go 6 more inches and be safe. actulally ive got lots of experiance putting large signs in the ground, just not pricing them out......and im not trying to rip my customer a new one, i dont like to rip people off like many signs shops do......for example that last one i was at.....
iSign
I'm sure you'll go far in business
Sounds like you have everything together except for your price and installation depth.
Your times seem way too conservative. Thus, your prices will be too low for any area regardless of the surrounding price scale or how good a customer he/she is. You’ll get interruptions, things will go wrong and just plain miscellaneous times spent that you aren’t counting on will enter into your final timeframe. Boost those numbers and protect yourself.
The posts should probably be 4” square tube for that height. It will get might windy at 12’ and although the posts will withstand it… I don’t think your customer wants a sign swaying at 12’. Also at that height, your post should go at least 4’ in the ground with a 24” diameter cement hole and a footer at the bottom.
… better safe than sorry :thumb:​
imaSIGNr
30" in the ground is a bare minimum. You need to get below the frost line and this size needs to have some concrete added if you're only going 30" ( Sauna tubes )
I think you've underestimated your time involved in this project also.
Thanks for the advice thus far, i did think my hours were a little light, and i was planing on concrete in tubes forgot to add that info, the most i have ever put a sign in the ground was 36" deep,they were 6x6x14's wood post with a 4' stop sign on them (and that was vdot spec). i was considering going deeper and renting a nice auger. please keep advice comments coming...
wildside
you need to consider windloads!!
at 12ft off grade, i wouldn't even consider the posts being less than 4ft in with concrete. you could check out the united states sign council, they have literature describing windloads and how to calculate them - i would also switch over to maybe 5" or 6" square tube, those sticks aren't as strong under heavy wind as you might think
in all your figures you never mentioned sign permits, you may want to check if you need to have engineering paperwork to accompany the permit or even to obtain it, this is not your standard slam bam thank you maam....
mounment tenant signage like this needs to be totally thought through keeping traffic patterns and line of sight in the fore front along with functionality, maintenance and tenant panel changes in the future
S
SignTech
Guest
Every one is Soooooooooooooooo right about the depth in the ground. 1/4 of the total sign height is highly reccomended. See Mark Roberts training video .... yep Gino ir 100% .... consider wind load ... or just have the local engineer give you some help at the zoning office .... they will help you. Big job sir .......... best wishes ............
Yes i Do need Permits, I may downsize the the panels to 15" x 60" making smaller by 1.25' and lower it to only 4' to the bottom of the sign making it 10' to the top of the sign, will 3' of depth be enough then right? and i will most defintaly be calling miss utlity line marking service.....
That's a call no one can make for you. You must find out what the local authorities have to say and then make sure you do at least that. If they don't have an answer.... remember, whatever you do, it will be on you and you alone to pay the consequences if something goes wrong.... it's always better to be safe than sorry. I knew a guy one time said these signs are only going to be up for less than 6 months. The customer told him they were temporary. About 1-1/2 years later one of the panels broke off and blew into a car or truck while it was driving past. Big time law suit. All you need is for 'FLESH' to get hurt, injured or worse and you'll be named on the lawsuit so fast, you won't know what hit cha.
Even at 10' out of the ground, I would still be at least 4' deep.
:Oops:3' deep is for temporary 4' x 8's and real estate signs.
If this is a good customer….. give him good service and advice…. not just a good price. :thumb:
JS
Out of your league as of yet.
This job sounds a bit to big for starting out. This job must be engineered. The area you live in is going to have criteria for this type of sign work (how high, how far off the ground, and many many other things). This job should be done by a licensed GC which is probally a requirement of the building dept. in your area. Perhaps farm it out and take a cut of the profit or something can go wrong and the sign can fall and cause a major accident or worse even kill someone and your liable. The 30" in the ground was what led me to believe your not up to this type of work yet.
imaSIGNr
And don't forget to call "Digsafe"
For this one you should consider "farming" out the pylon construction. You can still make $ on subbing it. You can do the signage for it .
