last nights 4 hour truck logo
iSign
well, I put this job off for 2-1/2 weeks... so when he called yesterday, I couldn't help myself & I said yes... I did have something to show him... but I wanted to put some finishing touches on it & would send him an email that evening. Another busy day at the office & I couldn't even start on it until 6:00 but I stuck to it until I had something I was starting to like. At 9:00pm, I finally sent him a version with golden tint to his name & the LLC panel, a red/burgandy prismatic on "HAULING" (in a different font), and red outlines all around. That file had no photoshop shadows either...
...but then I decided to do another variation, & switched HAULING to Steve's "Graphina" font (sorry for all the condensing and italicizing... I usually wouldn't f-up a perfectly good font...:rolleyes: ) and went with some cooler colors all around.
I set up about 8 layers in illustrator, then exported as a .psd file & through in all the requisite Photoshop effects us digi-print hacks just can't resist :Big Laugh
I made a second copy of the "Correa" outline layer & deleted everything above the top of the wood panel, so I could add a drop shadow to that layer & have Correa only cast a shade on the rest of the logo, but not on the truck.
I know that's kind of unnatural, but I wanted to get out of trying to print the fuzzy shadow on clear, or simulate a champaigne gold outline outside of the shade so I could put my cut line out there. I've done both those methods, & hoped the job would look fine with no shadow falling on the door. I think it looks OK, what do you folks think?
I'm thinking I will fix the main panel to have all the "wings" be curved like the bottom pair, & although that purplish woodgrain finish doesn't exist behind the diamondplate oval, I'll extend a woodgrain oval so I can downsize the diamondplate panel about 80%, leaving a thin reveal of the wood.
I also want to widen the kerning on the phone number & beef up the navy blue stroke a little.
I'll wait to see what the client thinks, but am always interested in opinions, & critiques.
ecsw
Very nice. I'm not sure if you'd be better rounding off the other wings or making the bottom ones square as well.
iSign
I'm not either, but I think the angled wings fight with the angles of the text, where the rounded ones might echo the oval curve & tie in better.
If I do it, I'll post it & we'll see.
iSign
so far, it is only a computer drawing, but it will be a laminated inkjet print, done on white control-tac. On my edge prints, I can do fuzzy shadows on clear & print a white base behind the rest of the graphic, but the resolution is so much better... I don't use the edge for rastor images anymore & I do like my photoshop effects too much to leave them out just to drop a shadow on a door. Besides the size limitation is another issue, & my printing costs are far less.
here was the original color scheme:
iSign
I'm expecting to hear from the client today & finish this thing up.
I'd really like to get a little feedback on these if anyone has suggestions.
thanks
Steve G.
Hey Doug,
I prefer the first set of colors as well, but they both look good.
I would try Rotating Correa Slightly counter clockwise to get rid of the illusion of it dropping.
Maybe a solid color fill for the wings since you have a pattern under LLC.. or vice versa, and try one other font for correa for the cust to pick. Maybe LHF Red Sable??
steve
Jillbeans
The spacing of Correa bugs me.
Is there an alternate "r"?
The o-r arm is awkward and the a needs moved over a tad.
I'd also move the word up just a bit and not crowd "HAULING" so much.
I think I would make the LLC small, in a block letter, and not highlight it with the oval.
I'd make it have a rule line on either side and center it in the bottom "wing".
I prefer the blue. Has that Island feel.
Love....Jill
Steve C.
What Jill said......
That is a beautiful script, but I don't think it works as well as another might.
Some words just don't click with some scripts.
Not only does the o-r conection look awkward, but the ending on the a does
not look right. Does it have a swash ending? Maybe that would help.
Some dont like swoshes, I dont like wings, but that's just me.
iSign
OK,
I tried some quick looks at some of the ideas offered.
Good eye on the rotating Steve G. I had rotated it clockwise, because to my eye it needed that, but I rotated it halfway back for a look.
Jill, I also thought in retrospect that I shouldn't crowd hauling that much. I also tried to make some corrections to Sophia script, but as shown in my comparisons, I had to work on that o>r a bit & still couldn't transition better without redrawing most of the o. I also worked on the r>e to get a better transition. I tried the idea both you & Steve G mentioned of losing the little steel oval panel, but then when I tried losing the "wings" for Steve C... I put it back in. I did try another script because of all the inherent challenges with this spelling in Sophia. Unfortunately, there is no alternate "r" or a swash "a" in Sophia Script.
Neither of these variations have been worked on as long as I would expects to have to before I didn't see dozens of additional design problems to solve... but I'll post them fopr feedback on which, if any, of these ideas might look to be worth persuing to others here. And I'll also have to show the client.
Steve C.
I don't have that font so I changed it as an bitmap. would be easier as
a vector.
iSign
:software
...no worries Steve, I'll give you that font :Big Laugh
...how do you think I got all mine :rolleyes:
no, seriously, thank you for the ideas. I could see that the swing away from completing the o would have to be completely redrawn inside the o, to ever swing up nicely to the r, and although I was thinking of some of my more script savvy peers here when I began fixing that lettering... I guess I just didn't want to work that hard. :Oops:
anyway, I printed a sample of the first version at the top of this thread & got approval to print the final truck graphics just like that. $400 for design work with no revisions, $600 for 2 doors plus the truck number & the various other tare, puc & dot numbers.
Steve C.
A script can be created with all the letters the same height and weight
that will ballence and look good with any letter combination. The problem
is, when creating a really good handwriten style, that the letters will not
be the same height and weight. Some will bounce below and some above
the line. Arthur Vanson said the same thing somewhere, maybe his blob
over at letterheadfonts. Basically, you cant expect every word to look good
in those handwriten loose styles.
All in all, I think your logo looks great.
skyhigh
$1k for the package.....good job Doug.
I like the prismatic style on the "Correa", along with the blue on your first example..... but...... the wings are way over done. Too many trucking co.'s using a version of the same thing.
