Lexan sign face price checking please!
Happyprinter
Need to get an idea on what everyone would charge for a 4'x12', 3/16" white lexan face with full color printed on clear vinyl then laminated. I'm coming up with $1,150.00. To high? To low? Let me know how it compares to your area.Thanks
sfr table hockey
If you have not done one like that (printing on clear laminated), make sure it will not be washed out when lit. I think on its own clear will wash out.
Normal is to use the front layer backlit media printed and a 2nd layer reverse printed on clear for the back side. Still need to laminate the front.
Up here cost on the roll stock lexan 52" is close to $260. Do you have to buy the lexan or is it supplied? Are you installing and do you have to add a strip on top of the sheet to hang from?
Happyprinter
Yes we are buying the lexan and also yes we are adding a 3/4x3/4x1/8" aluminum piece on top. Also got a price on the lexan of $228 for the 4'x12' piece. Thanks for the direction. This is the first time we have not used cut vinyl for a sign face. We will look into the backlit material. Obvious choice. Chalk it up to a Monday.
sfr table hockey
Oracal has Orajet 3850. Right now I would not suggest 3M.....
If you try a couple test prints. You could do a double pass when printing onto the 3850 but you may find the image gets too dark when viewing in the day but looks good lit up.
Or:
Normal print on the 3850 and then do a second reverse print on clear and mount that on the back side of the lexan. When you line it up you want it close but from what I read it does not have to be exact. This looks normal in the front in the day and yet when lit the added clear on the back helps with better color and not look washed out.
On a smaller run I might try to print the clear normal way with crop marks, then laminate the clear with the 3850 backlit (don't cover the crop marks) and use the crop marks to line your print. Send the print job again over top the 3850 you just put over the clear. This may line things up easier but on a long run you still may be off as much as if you tried to line things up on the lexan. All depends how the print feeds with the added layer.
As for price I am still in the same boat as you. On other things I have been a bit low, so as is, I think you are about what I would say...... so does that mean we are both low?
This is the Prem. Section so it would be nice to hear from others if they can.
