Oracal has Orajet 3850. Right now I would not suggest 3M.....
If you try a couple test prints. You could do a double pass when printing onto the 3850 but you may find the image gets too dark when viewing in the day but looks good lit up.
Or:
Normal print on the 3850 and then do a second reverse print on clear and mount that on the back side of the lexan. When you line it up you want it close but from what I read it does not have to be exact. This looks normal in the front in the day and yet when lit the added clear on the back helps with better color and not look washed out.
On a smaller run I might try to print the clear normal way with crop marks, then laminate the clear with the 3850 backlit (don't cover the crop marks) and use the crop marks to line your print. Send the print job again over top the 3850 you just put over the clear. This may line things up easier but on a long run you still may be off as much as if you tried to line things up on the lexan. All depends how the print feeds with the added layer.
As for price I am still in the same boat as you. On other things I have been a bit low, so as is, I think you are about what I would say...... so does that mean we are both low?
This is the Prem. Section so it would be nice to hear from others if they can.
