Logo Design - Thoughts?
Border
I'm working on a logo for a new company and would appreciate any constructive input.
The owner wants the lighthouse and light effect incorporated in this somehow, for sure.
Here's where I'm at with it so far. Working in black & white for now but the ultimate goal would be to keep it more on the simple side and down to 2 or 3 colors. Something that can easily be adapted to shirts, cheap coro yard signs, letterheads, etc. On the truck, there's a good chance some part of it will be done or accented with chrome vinyl as he really likes that look and had some on his last trucks.
Trying to stay away from the traditional North Woodsy/pine trees and water/deer themes and keep it more modern somehow.
My idea is that the "swoosh" below is supposed to represent a wave coming ashore. I was thinking it would be cool to make a cliff coming off the bottom of the C down to the wave somehow but so far have not come up with a good way to do it without losing the C in the design.
The lighthouse started out as clipart but I deleted most of it and changed up what was left so it is not such a standard image. I also created, or attempted to create the light beam effect, trying to keep it simple.
Ok, hopefully, I don't regret posting this here. I know I am nowhere near the talent level that so many of you have. I'm here to learn and am trying! I usually don't have to do very much actual logo design.
So far the guy is really liking the concept but I know it can be better and I hope to get it there.
Thanks! :toasting:
Jillbeans
First thing I would suggest is to lose the extreme slant on the copy.
I think I'd also lose the drop shadow because you don't have it on all the elements, and don't need it really. And lose the outline on the swoosh.
I'd make North Lake tighter to the lighthouse, put CONTRACTING in a reverse panel, and anchor the lighthouse to that rather than to the "C".
(this might mess up the light effect somewhat)
Love....Jill
I'd start by removing all but one.... maybe two light strokes in the beam and not having them converge creating such a heavy spot in the small part.
Also, I'd make the railing less intricate for possible problems reproducing down the road.
Border
I was thinking the same thing on the railing being a bit too detailed still. Good suggestion on the light beams too, thanks Gino!
bob
It looks like a convulsion. Way too much going on with lines here, there, and everywhere along with acutely slanted text jammed into objects and gratuitous drop shadows. Drop shadows usually are a sign thing, not usually a logo thing.
Border
Here's another stab with the advice given thus far.
Jillbeans
I like that one better. Still do not like the italicised name.
And Gino...whatsamatta with a bit of junk in the truck?
P
ProWraps™
Guest
good luck reproducing that with embriodery, cut vinyl, etc. the beam over the text will kill this as far as usability. look at your clients needs. they will need t shirts screen printed, probably embroidered, cut vinyl on their trucks etc. design this in one color then go from there.
did you sit down and pencil out what the medium/s they will be reproducing this in will be? or a conceptual framework for their business? or did you just start designing?
Border
I did start with some basic sketching. I don't see the problems reproducing in vinyl or embroidery with this. It's 2-3 solid colors-max, no gradients. I am designing with cut vinyl in mind so everything will be cut-ready in the final design with proper bleeds, etc.
This would be a piece of cake in cut vinyl.:help
Border
Jill,
Italics removed from North Shore. I do like that more. It sets better next to the lighthouse. Thanks!
Any more thoughts?
signmeup
I don't think you need the little lines for the beam effect to work. It just needs to go thorough enough of the lettering to suggest the effect.
Border
I see what you mean....One thing I have to keep in mind is how to achieve this when it's done on a black truck, for example. It won't always be on a white background. Many times, on vehicles especially, the colors used will be silver and charcoal metallics, or combinations of lighter and darker shades of other colors to achieve the light beam effect.
I appreciate the input!
-and will be working up some more examples on different colored backgrounds.
TheSnowman
When I think of a lighthouse, I think of big rocks and boulders that you see on the east coast around the light houses. Maybe you could do something like that one the bottom text instead of just the box w/ reversed letters.
Border
Thanks again for the suggestions. I hope/think it's moving in a positive direction.
Here's where I'm at now. Tried to show a few color variations too, so that the client could see how it might work on different colored trucks.
I like the last one best, but you're leaving too much negative space in the corners. Also, the colors are not very appetizing.
