Logo for the bashing
Sabre
Hey guys!
I was approached by a company with very little input or preferences (isn't that how they all start?). He wanted black and chrome to decal up his trucks and then go from there. I'm please with where I got to in relatively little time, but am having a hard time placing the "industrial" text. Without any input, I intend on submitting this to my customer tomorrow; but the more time I spend in here the more I value everyones opinion.
Please be gentle, this is the first time I've really submit any of my work for a professional to critique.
Thanks in advance!
Pro Image
This is just a observation but the word INDUSTRIAL is competeing with the overall design.The only thing I would change is the word "industrial"..........I would make it smaller and move it over to the left and end before the Q and remove the chrome box also...................
Sabre
Funnily enough, that's exactly how I had it to begin with but I kept screwing around with things trying to make it better. :p
iSign
It looks good. no bashing from me... but while you are still messin with it instead of posting what was approved by the client already... did you try the descender of the Q coming down at an angle towards 5 o'clock instead of 6?
Also, the circle you started with appears to be about the height of the flat letters, instead of larger like the "O" or "Q" of that font would have been. Maybe it would look good larger like that, or even exaggerated to even larger then a proper "Q" would have been.
You know those socket drivers that have like a U-joint right near the end? I was picturing that happening & swiveling (& lengthening) the Q handle along in line with the name... possibly with "industrial" written inside the handle??
Anyway, looks good already... just thinking out loud
Pro Image
Doug has a good idea move the angle of the wrench to "5 o'clock" or so and slant the end of Indurstral to match the angle of the wrench.........Like I said before just a observation................
Rod
Use a raised screw for the letter ' Q '
For the letter ' Q ', the slotted screw should be raised and have consistent shadow.
For whatever reason, it did not initially click in my mind that you had a screw as part of the letter ' Q '.
Perhaps a Robertson, Phillips, or tamper-proof torque screw would be more recognizable?
The Vector Doctor
Chief Bezier Manipulator
If it is a wrench shape, then maybe the shape should be a nut in the middle rather than a screw head, especially if the Q is wrapping around that object.
JMDigital
Doug Allan said:
isn't it supposed to be a ratchet, with the simple forward/reverse dial showing.
I see it also as a ratchet.. or "Torque Wrench" Like the pic I attached.
I like it. It would be good to compair to the ide to move the angle of the wrench to "5 o'clock"
iSign
Rick brings up an important point of identifying the client a little better to allow more intellligent discussion about their logo.
Here is my take using Futura extra bold, with the inside of the "O" changed to perfect circle to match the modified "O" used for the "Q"
Sabre
Thanks a ton for all the input!
To answer some random questions:
They are primarily small engine mechanics/welders, but did not want to have a name that limited them. Just 2 guys runnning out of their truck on their cell phones.
My intention was what Doug saw, as a reversing dial on a Torque wrench and/or ratchet.
Doug, I especially appreciate your enhancements. I had hung onto that other font from a previous idea; the futura seems like a much better fit. As does the "5 o'clock" angle, in my opinion it makes the shadow look a little more complete... Does that make any sense?
This also raises another question of mine... If you're presenting a logo to a client that has chrome in it, do most simulate the chrome with a gradient? Or simply use a grey to represent like I have? Do you take it a step further if you're extremely confident and mount the vinyl on sintra or something for your presentation?
Thanks again! I'll play with it a little bit more later this morning when I have more time.
iSign
A sticker might be chrome, but if you design a logo for someone.. they will use it in several situations. If they want a metallic look in there logo, I think you should try to give them one that can work in a cheap black & white letterhead, or a newsprint ad or sale flyers etc etc.
Then for expensive door lettering, you can use metallic films.... but I will often use an overprinted black gradient fill on top of silver metallics for a true metallic version of the simulated metallic logo design.
I'll find a pic of one i just did like that.
wildside
also be sure to inform them that chrome does not last outdoors very well, books and swatches say 2-3 year outdoor durability, but most i have seen turn nasty gray/white in a year and start to flake off within 2 years
i never recommend using chrome outdoors, but thats me, i want to see it looking nice for years and years, maybe a metallic silver might work out better
oh, i think the design looks good with the Q tweaked to theside and the industrial shortened up
iSign
This job has chrome. I printed a sample on a black aluminum license plate before getting final approval to do the guys truck.
He came wanting a magnet :Oops:
I told him his truck looked too nice for that, but he said he didn't really want his name on the truck. So I took photos, & went for an understated smaller look & got the plan approved with just illustrator artwork first. (I designed the logo last year in bright colors for their landscapers shirts)
Then I made a few small edge print variations. I used black & chrome foils on white vinyl. I made the small metal plaque out of the sample I liked best & he went for it. We laminated it for him too.
Rick
I like the idea, especially Dougs solution of turning it at 5:00 oclock. but I don't think it's totally working. A disembodied hand or head does not look totally out of place, but you are taking an element not instantly recognizable as the main feature of the logo, it also looks like a tie rod arm. I played around and did this.....not that this is the solution, but just thought I would throw it out there....then you can add icon style images to the back of a business card or on a t-shirt or the trucks of services they provide.
logomotive
I really like the original concept. It naturally reads as a Q especially rotating it slightly. Just needs more emphasis that it is a torque wrench. If it were my design I would work on the original design. I think you really nailed it down with the BOLD font also.Just My opinion though.
