or he could solder them onto the existing PCB.Just 2 generic optical endstops on a custom circuit board wired in parallel. About a $5 part if you know how to solder, just need the connector, some perforated circuit board and the 2 optical switches. The optical switches should have part numbers on them, but they are partially obscured in the pic. Probably around $0.80-$2 each.
Yeah, it may be at that point where we build it ourselves considering this specific part is not made anymore. Just hoping someone mightve seen it somewhere. Just trying to keep this guy going for a month or two longer so we can keep pace up in production. New machine coming at EOY so just trying to not have to limp in production with 1 machine.
Same here except for 1, the Mimaki CJV150. If you install the newest version of the slider board with a firmware lower than 2.0, it fries the board. In this case, the change from Version 1.0 to 1,1 is 1.1 adds some circuitry to clean up the signal and handle more power modes. I read it should be backwards compatible but doesn't seem to be working for OP.50 years poking around in 100's of printers i have never seen a firmware update or a version update physically damage a sensor
you are in CT. if you think it would help we could loan you one of those weird little digital oscilloscopes (the size of a large digital DVM.)Will give all those responses a shot and let you know if it comes back. netsol it is an ATP Printer Evolution EOS dtf printer.
