No..I havent..did you try calling summa?
Thanks Phil for reply...We(Airmark) have the 399-610 cutting heads in stock. The bracket that holds the blade holder cannot be purchased separately like Frank mentioned, so you would need to purchase the entire head if that bracket is busted. I have had customers glue the bracket back together as a temporary fix, so you might try that if you don't want to purchase the entire replacement cutting head.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
[email protected]
They are easy enough to change over, but the heads are very expensive ! Around 500 Euro as you have to buy the complete drag headI have the same problem of small crack in dragholder clamp. Is it simple done to change the head by myself?
Thank you all!
Well relatively easy in that you don't have to dismantle half the machine to get to the part like you do with a lot of components! Recalibrating a head is normal when you replace something like that, and setting up print / cut adjustments is something most people can handle, so in terms of difficulty I would say it's one of the easier jobsAre you sure? Change the cutting head it's not just removing the old one and fitting the new one.
These are the steps a technician should follow to do a good job:
- Remove old cutter head (ok, this is easy)
- Move OPOS sensor from the old head to new one (this is easy too)
- Fit new cutter head ( ok, just a little attention with heights and orthogonality)
- Adjust coil parameters (....)
- Adjust right margin offset (not that important but if it is done it is better...)
- Adjust OPOS offset and other calibrations.
If you are really stuck as I know you have been looking for a while, I can get it done in the UK for you if you sent the part her
Check this shit out. this worked for me for years before i bought a new head:I have the same problem of small crack in dragholder clamp. Is it simple done to change the head by myself?
Thank you all!![]()
