I'm running 6.6v1 on my new machine with
windows 7 pro,
and here's how I got it to work.
If you have 7 pro.
Download and install virtual pc, and
windows xp.
Start
windows xp.
Install LXI 6.6v1 in xp.
Install the hasp driver so xp sees the dongle.
Now you can exit xp.
In your
windows 7 program list should be "
Windows Virtual PC"
In that folder is "
Windows XP Mode Applications"
In that folder should be "VE LXI Master" Right click on that, and
drag it to your desktop for a shortcut. (you can do the same with
production manager)
When starting the program, right click on the virtual pc
in the taskbar, and in the menu select "manage usb devices"
You have to click on "hasp" and then click "attach"
I'm using a usb-serial converter cable that also has to be "attached"
It works fine this way and was kind of funky at first,
but I'm starting to get used to it. I only use VE for cutting,
all design work is done in Corel and saved as an .ai 1.1 file
and imported into VE.
Hope this helps.
