LUV DEM TIGERS
Okay, using Coreldraw 12 or X4, how can I make a series of dots into the shape of an oval? I know how to "fit text to path" but if I had a series of dots, how would I do that?
If you want round dots then you're pretty much stuck with entering a line of periods in a font that has a round period, drawing the target oval, and then fitting the line of periods to the oval with the Text->Fit Text To Path function. When the line of periods is fitted to the oval you can add or remove periods as necessary merely by selecting the end of the text with the Text tool and then backspace or type periods as necessary.
If square dots are OK, just draw the oval and then change its line type to a dotted line. You can adjust the size of the dots in the line by using various thicknesses of outline on the dotted line.
There is a font called Common Bullets. The letter Q is a dot.
I use fit text to path with that font
I looked into this a while ago for a job I had. There isn't an easy way to do this in corel, you can fit text to path easily enough, but you can't fit vector shapes to a path. Someone did write a corel script that will allow you to do it, but I haven't tried it myself.
http://www.oberonplace.com/products/fitobjects/index.htm
This is what the artistic media tool is for. Use the brush option.
can't set a stroke of a line to be a dot?
edited: dang, thought i had the option in illustrator but I guess I can only make dashes![]()
