Matthews cleaner alternatives
Devon19515
Does anyone have alternatives for Matthews 6410SP cleaner.
What do you use to clean/prep aluminum before painting?
Alcohol and Acetone seem to be the active ingredients
PPG's H2O-So-Clean SWX350 is similar.
we use denatured alcohol and/or paint thinner to clean/wipe raw surfaces depending.
for painted surfaces, we just scrub with isopropyl alcohol&water after removing any adhesives with RapidRemover.
rcali
I was a finisher for 4 years, I was taught to clean raw metals with a 220 radial sanding and then wipe down with lacquer thinner and blow off with air before priming. I was discouraged from using Matthews cleaners and when I did try them just to test why I remember feeling like they left a residue. Anyway, that's what worked for me. In an offshoot manner, I do graphics now and we clean everything with IPA.
DL Signs
Never go against the family
Acetone leaves no residue, use that to clean everything from painting to welding. Denatured is another good option if you don't want to use something as hot as acetone, it's a little more tame.
Back in the day we used to use whatever thinner or reducer that the finish used for final clean.
