Need Help Mimaki JFX200-2513 Stepper Motor Help
BenBo
Hello,
I am hoping some of ou wonderful people are able to help me with my JFX200-2513 as I am having an issue with it at the moment. I went into the workshop yesterday and found that it had this error on the screen SYSTEM HALT (2) 506: STATION SENS. So I turned it all off and back on again and it seemed fine, then I heard an awful noise coming from below the head. So I turned it all off again and opened up the panels below the station to see what the noise was and it seems to be coming from the stepper motor that controls the station Y axis, but I am not 100% sure of this. I have attached a video of what happens when I startup the machine. I can pull and move the belt and it moves the cogs etc and changes the station height but the motor seems to jam or stop and makes that awful noise.
So do I need to simply replace the motor? If so, where do I find one and is it easy enough to do? I can't seem to find any online that easily. Im UK based.
Any help or advice would be greatly appreciated
Ben
Smoke_Jaguar
Might be the endstop switch not reading or damaged if I were to guess. I think the station PCB has an LED light for the switch/sensor, try moving something back and forth between it and see if you can see the LED blinking.
BenBo
Thanks for that. Where would the station PCB be? Is it easy to see?
Smoke_Jaguar
Track the station motor wiring back and it should be the board that the stepper plugs into. Have a service manual you can reference?
The sensor looks like #28 below. Like smoke said, go into service mode and test the sensor by moving something in and out of the interrupt sensor and have someone watch the screen to see if it flashes on and off. If it doesn't, either the sensor or the board it connects to is damaged. If it does flash on and off, check to make sure the flag that interrupts the senor is positioned correctly. You can get into service mode by holding the Remote and Function buttons while powering on. That will add the #Test menu to your menus and then you just go into the sensor menu. That sensor is simply labeled, Station.
well, you joined in 2020...the fatigue hasn't set in yet :)
i got really good at one point, at citing old threads and simply linking the same questions
this one is new tho', and i love stepper motor diagnosis' ...and its usually not the motor
Smoke_Jaguar
On a JFX500 we have, the station board had a bad IC. Just resoldered in a replacement and spent $12 instead of $500. Might've been a stepper driver chip, would have to look it up if this were the case. Usually ink in sensors or bent/maligned tabs tend to do it.
Also, if I don't want to help someone, I say so. My DMs have quite a few f-off type replies when new people who join without even bothering to post contact me out of the blue.
Adam Vreeke
Knows just enough to get in a lot of trouble..
Personally I have been contemplating asking for your phone number and get you on speed dial.
Oh come on.
i have gotten calls 19 hrs a day, or more for over 50 years.
it just seems to be one of those things, it goes with the right brain thing, i think
BenBo
Thank you for lettingme know. I think im being a bit thick though as I cant seem to find this sensor on the machine, I have tracked the cables back to the central IO PCB but maybe I am just not looking in the right place? thank you for all your help so far
