We did give several quotes, there are more adhesives as part of this job, and this is one of the options I think they are going with this option, and full color is not one of the options they want to go with. We actually gave them a better price doing them in full color. I think the best way after thinking a lot is putting several registrations blocks on the left of the solid green and then, applying registration for the white and for the black and in that way making less usage of white than of the black.Personally, when looking at those quantities, I would give the client 2 prices, one for cut vinyl graphics and one for print.
I don't believe the vinyl colours would be too hard to match as a printed graphic & suspect the client would go for the printed option if priced accordingly.
If we were going to go down the route of cut vinyl graphics, we would Cut a quantity of the green blocks, then cut the different coloured lettering so it pre spaced to match the layout of the green blocks. At least this way we would be able to line up and apply the lettering to the green blocks in mass rather than individually.
These are going on cars, several colors.printed if you can hit the green color.
or
printed on green vinyl, with a printer that has white ink option.
or
print&cut on green vinyl, with white lettering contour-cut out if applied to a white substrate.
These are going on different color cars. Will look into that media. They are actually specifying Oracal 641.What is the end product?
If it's going on a white panel or something, void cut the white areas out of the green, then use 3m 7725 black (has a clear backer) to cut the black lettering plus one white letter for registration, line the letter up over the void, tape it down, then split the liner when your sticking it so you don't also have to remove a black letter.
We were planing on running on 48" roll. Yes there will be a lot of waste, but this is only one of the decals, there are some more and all work on combination of 4 (light green, dark green, black and white) colors. Will try to maximize the roll as much as possible. But sometimes, saving a bit on waste you loose it on production time, something that we all not look at much, and can be a lot more costlier. They are specifing Oracal 641 which is a very economical vinyl.I would also give two prices and hope they bite at the printed. What size vinyl roll are you using? 30"? Can't do 2 up on 24" - that sucks. Don't forget to account for all the wasted vinyl. I would try what the above person said, maybe try and do 3-4 at a time but cut a little registration mark so you can just line it up. A light table might be handy! I would also cut the solid green then overlay the black, then the white. Going to be a big job.
Don't have a Gerber Edge. Would be nice as I would save a lot of weeding, not shown in this decal. Yes, we need to match that color they are specifying. This is an across the world project, and specifying the actual vinyl color will guarantee color match across all installations.Print/cut them on a Gerber Edge. Use the correct green (apple?) and print the white and black foil onto them. This will get them nice solid colors with a good bright green, in a single layer.
Wide format printing is the best/cheapest/easiest way to do these, but some customers want a brighter green than you can usually accomplish that way (CMYK printing).
