Thank you….my vj1617h needs to be shaken daily (other colors every other day)
there is an absurd amount of titanium in white ink. AT BEST you will have no consistency in the printed white, if you don't follow advice
at worst you will clog ink lines and requently replace expensive printheads
I got mine 6 months ago. Every 24 hr, printer prompts to shake white ink. I only do it then. Haven't noticed any issues with white ink.Good Morning All,
Thank you for accepting me. Here’s my question.
We just received a Mutoh Xpertjet 661 UF printer. While doing the set up the tech advised me that the white ink had to be shaken every six hours! Has anyone heard of this? What do you do on weekends?
The machine was purchased to make Braille signs so I don’t see a problem with the white ink at this pointShake 5 days a week and you’ll be fine. You just need to keep the titanium in suspension. It’s a small machine with a small recirculation pump so it’s not able to do what the bigger machines do more automatically.
It’s more important to use it. Shake all you want, if you’re not printing white, you’re speeding up the death of the channels.
Yes. Are you using a sticky mat like a seklema? If not get one. Clean the back of your substrates really good, use the sticky mat, and drop your UV lamp control percentage to 50% on all boxes and use machine width for your shuttle width as opposed to data width in the settings. Ink will cure fine with 50% and using the machine width gives it a little more time to cool for each pass. It will take a little longer but you won't be getting head strikes. Just save this in your ADA build up print environment and you should be good to go.I have a new Mutoh 661UF. Has anyone had a problem with the substrate ( for example, Rowmark / IPI sign acrylic) that you print on warping while using the buildup setting?
Let me know if you are interested. I have one barely used. Detroit area.Does anyone know someone that might be wanting to sell their 661UF because they are upgrading? We could use one.
