One of your plugins also has debugging turned on.
this is all in the console
Consider using 'dppx' units instead of 'dpi', as in CSS 'dpi' means dots-per-CSS-inch, not dots-per-physical-inch, so does not correspond to the actual 'dpi' of a screen. In media query expression: (-webkit-min-device-pixel-ratio: 2), (min-resolution: 192dpi) (index):50
Consider using 'dppx' units instead of 'dpi', as in CSS 'dpi' means dots-per-CSS-inch, not dots-per-physical-inch, so does not correspond to the actual 'dpi' of a screen. In media query expression: not all, not all, only screen and (-webkit-min-device-pixel-ratio: 1.5), not all, only screen and (min-resolution: 120dpi) (index):58
[cycle2] --c2 init-- jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] loader: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] overlayFxIn: fadeIn (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] overlayFxOut: fadeOut (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] overlay: #cycle-widget-skin-overlay-356 (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionFxIn: fadeIn (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionFxOut: fadeOut (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionPlugin: caption2 (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionTemplate: {{name}} (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] caption: #cycle-widget-skin-caption-356 (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] centerHorz: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] autoHeight: false (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] centerVert: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] pager: > .cycle-pager-container .cycle-pager-inside .cycle-pager (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] next: > .a3-cycle-controls .cycle-next (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] prev: > .a3-cycle-controls .cycle-prev (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] swipe: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] delay: 1000 (number) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] speed: 2000 (number) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] timeout: 4000 (number) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] paused: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] fx: fade (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [0] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/aprons/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [1] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/basketball-goal/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [2] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/checkbook-wallet/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [3] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/custom-iphone-cases/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [4] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/iphone-5-case/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [5] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/car-accessories/license-plate-frame-chrome/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
event.returnValue is deprecated. Please use the standard event.preventDefault() instead. www-embed-player-vflXHU025.js:28
Anyway, yeah, like it was said before, it's not really appealing.
it would be if you offered
signs and t-shirts, but not web design. so, if you're a
sign shop, nobody expects you to be a web designer OR a web developer.
if you still decide to stick with it, add some padding to your forms. the input fields and captions are right against "the wall"
yeah, i'd look for a different template.
and i guess i should probably stick to development and stay away from
signs LOL
