1. I am going to change the second font I was in a hurry too get something done so that I would ba able to get input on the logo as a whole, but I had the intentions of changing the second font, definitely.Fred Weiss said:It's definitely better than the first try but I have some problems with this one as well.
1. Your font choices are both gothic. Is that your intent? The primary font is fine but why make the secondary font in that group as well? It's hard to read and sends a message that may be strange and repelling to some.
2. Will you be producing or making a market in printed vinyl graphics? The use of gradients in your logo would imply this is the case. If you are only dealing in cut vinyl, you won't even be able to produce the artwork you have created. If you are dealing in printed and cut vinyl graphics, then you should make that clear in your basic self description.
3. The use of a plotter and roll of vinyl means everything to you but little to your prospective clients. Good marketing dictates that you relate to your customers wants and needs ..... not your own features and capabilities. You might be better served to provide an image that the customer will better relate to. A sketch of a sign perhaps or a figure involved in the process of signmaking.
Thanks for your input I am definitely going to play around with it more I just needed to know if I was heading in the right direction and what changes should be made.idsign said:Back in my in-house agency days, they always asked me for about 6 versions on 2 or 3 themes. They could immediately throw out at least half of them. Try making up 3-4 more using the same font for Vinyl Graphix, try the fade vertically instead of left to right and back. Just take a look at it. Also, the contour with does not allow interior drop outs like maybe it should like inside the V, G and a. Try that and a drop shadow option. Maybe even a Photoshop type shadow where the edges are not hard but soft.
The font you chose for Vinyl Signs and Lettering is just too "machiny." Maybe do one with a good readable signpainters script font and another with just a basic easy to read san serif - not plain old Arial but something more current like Frutiger / Humanist.
I would remove the doodads at the end of the lines. They don't add anything to the message. I would not advertise for Roland and a less isometric / more hand drawn drawing of the vinyl roll and cutter would be more appealing (I think).
Mess around with it more and see what you come up with.
Barry
my 2 ¢ (alt 0162)
