My first Logo
rsantos97
I hope this is better than the magnetic sign crap I did. All critiques apreciated.
Fred Weiss
It's definitely better than the first try but I have some problems with this one as well.
1. Your font choices are both gothic. Is that your intent? The primary font is fine but why make the secondary font in that group as well? It's hard to read and sends a message that may be strange and repelling to some.
2. Will you be producing or making a market in printed vinyl graphics? The use of gradients in your logo would imply this is the case. If you are only dealing in cut vinyl, you won't even be able to produce the artwork you have created. If you are dealing in printed and cut vinyl graphics, then you should make that clear in your basic self description.
3. The use of a plotter and roll of vinyl means everything to you but little to your prospective clients. Good marketing dictates that you relate to your customers wants and needs ..... not your own features and capabilities. You might be better served to provide an image that the customer will better relate to. A sketch of a sign perhaps or a figure involved in the process of signmaking.
idsign
Back in my in-house agency days, they always asked me for about 6 versions on 2 or 3 themes. They could immediately throw out at least half of them. In your case, using the same font for Vinyl Graphix, try the fade vertically instead of left to right and back. Just take a look at it. Also, the contour with does not allow interior drop outs like maybe it should like inside the V, G and a. Try that and a drop shadow option. Maybe even a Photoshop type shadow where the edges are not hard but soft.
Mess around with it more and see what you come up with.
Barry
idsign
Back in my in-house agency days, they always asked me for about 6 versions on 2 or 3 themes. They could immediately throw out at least half of them. Try making up 3-4 more using the same font for Vinyl Graphix, try the fade vertically instead of left to right and back. Just take a look at it. Also, the contour with does not allow interior drop outs like maybe it should like inside the V, G and a. Try that and a drop shadow option. Maybe even a Photoshop type shadow where the edges are not hard but soft.
The font you chose for Vinyl Signs and Lettering is just too "machiny." Maybe do one with a good readable signpainters script font and another with just a basic easy to read san serif - not plain old Arial but something more current like Frutiger / Humanist.
I would remove the doodads at the end of the lines. They don't add anything to the message. I would not advertise for Roland and a less isometric / more hand drawn drawing of the vinyl roll and cutter would be more appealing (I think).
Barry
my 2 ¢ (alt 0162)
rsantos97
1. I am going to change the second font I was in a hurry too get something done so that I would ba able to get input on the logo as a whole, but I had the intentions of changing the second font, definitely.
2. I am going to be dealing with both cut vinyl and printed vinyl. I know gradients can only be done using print or with airbrush, or with the new gradient vinyl (which is expensive). I am going to be purchasing a versacam, would I be able to print the gradients on that with good quality? Good point on making my self description clearer.
3.The Roll of Vinyl and plotter were something that just came to my mind cause I couldn't think of anything else to use.
Thanks Fred for the input, I'll get back at it again. I'll post up the remake tomorrow.
:thankyou:
ChiknNutz
One thing I see is that it lacks overall unity. One thing to try is by using a complimentary colored "panel" or two (i.e. a skewed rectangle or triangle) to tie things together.
Like Fred said, try to match the fonts and clipart/graphics to the intended audience. If you want a gothic look, fine, but just consider what might appeal to potential customers.
rsantos97
Barry
my 2 ¢ (alt 0162)
Thanks for your input I am definitely going to play around with it more I just needed to know if I was heading in the right direction and what changes should be made.
:thankyou:
OldPaint
STOP!!!! tryin to use every available graphic effect that is available......you need to stick to basic..DESIGN &LAYOUT....now start over again........hehehehehehhe
supchaka
Just at a guess I'd say that 99% of the population isnt going to have a clue what your vinyl roll and cutter are. They don't know how letters are made, as far as they are concerned you hand pour them into a mold. Sooo with that said, I'd lose that look altogether.
Did you hand draw the upper text? It's either a really poor font, or you need to take a little more time drawing it. It doesnt look uniform... maybe I'm just tired because its late. LOL and just to add one more thing, I dont like the gray stroke on the text, it's too gloomy and doesnt add anything to your image.
Don't take it personal, I'll post something of my own for critique someday :)
dccas
I think I agree with most, the second font is hard to read, and I wouldn't use Gothic, try just an arial type, also, your first sign had a phone number, was it left out intentionlly? And that font I would definitely use arial, or one similiar
