I'm going to be critical becasue that's how I feel right now. It has nothing to do with you personally. Don't take offense.
The first thing that strikes me, oddly perhaps, it the word "Horsepower".
That word conjures up a lot of mental images. None of which are present in your sketch.
Were there an image of a horse, or a race car with an extrordinarily big engine poking out of the hood, or a graphic that invokes the feeling of power, or even a font that suggested speed and power, then the word fits. Otherwise it leaves me empty for something complimentary to it.
Then again, since the word is so striking in my mind, maybe the word itself is making enough of a statement. But I still think it's striking mainly because it lacks something.
Just me.
Spark is such an interesting word. It's kinda like the 'horsepower' thing. It begs me to jump in there and make it lean toward looking like
Spark! You've used a spark plug for your avitar so you know what I'm talking about. Plus, giving spark "the treatment", might create some contrast with the word 'Wraps'. Maybe like 'Spark' in a crazy, scratchy, (though legible), modern script and 'Wraps' in all Caps in the same font it is now. Maybe even one with a heavier line weight.
Maybe not.
Contrast is our friend. It can be made all over a design. So long as one contrasting pair does not interfere with or reduce the contrast of another pair it's all good. The simplest black & white sketch can contain a ton of contrast in size and weight alone that will give it impact.
That was an aside. I was talking about the word spark. But that's all I have to say about that.
You are selling Wraps. Unless that means wax
paper, aluminum foil, or chicken and stuff contained in a flat bread of some sort, then 'wraps', in my mind anyway, has something to do with "head-turning impact", a bit of "dazzle" and "super legibility" of the message.
Does your sketch look like your wraps? I think it should, to some degree anyway. That may not mean images of lightening bolts and tripple-shaded copy. Just something that looks like a wrap. Your graphic elements do lean that way in that they remind me of the material itself. But it could use some more punch.
I might be the only one who thinks that.
The revision's banner-like thing is interesting. Though for some reason, the top of the banner touching the top of the background graphic is un-nerving to me. Perhaps because it seems to distort gravity and balance. Perhaps it is my own gravity and balance which is distorted. Either way.
Maybe you could make the background graphic taller so the red banner sits comfortably on it, or make it shorter so the banner is higher, above the other graphic. That might increase the dimensional and/or depth effect. Anything actually, just something. For me.
The original is pleasing in it's balance and gravity. Look back and forth between the two and if you see the same thing I do in the akwardness in the revision then revise it. If not, then leave it alone as it pleases you.
Overall both sketches demonstrate a working understanding of design and I would do nothing to discourage that. You have a good feel for this.
I'll mention this too since you said you are a beginner, often, when we're making adjustments to try an improve a sketch, we'll make a very good one, not recognize it for it's potential, and then continue to adjust it until we reach a lessor design, and lose the good one that was a handful of adjustments prior. What I'm saying is; sometimes we go too far.
If I save each design that causes me to pause in reflection, then go on and adjust away, I still have the good one that I proceeded to ruin.
I like to avoid making the decision of my favorite until the next day, or at least after lunch, just to get myself away from it and into something else for a bit. Making a decision while being so close to it usually resuts in leaning toward the latter or hating it and deciding on the original.
Returning later, once the mind has been defragged of the project, gives a fresh apporach to the decision-making process and a critique can be made more accurately and confidently.
Thank you for the opportunity to be critical. It's helped me get it out of my system. Now, I can go on and relate to my family without being a nit-picky old fart on New Year's Day.
You Have a very Happy New Year too!
And
Good Luck
