Need Help designing my logo
juniorcdn
Hello,
I am having a little trouble coming up with some designs for my new logo.
My small business is called "JRCNC or Jr. CNC". I am trying to incorporate both of my skill sets which are CNC Milling and CNC Vinyl Cutting.
Does anyone have any suggestions on how I can bring both specialties together to appeal to my customers in a nice logo?
markz
try focusing on a sharp techy CNC and then "balance" the other copy. either incorporated / overlapp the CNC or below it.a triangular shape/text. augghhhhhhight !
Marlene
Just make sure you have something in the name of your company that people can pronounce. People hate sounding stupid and hate being put in a postition to sound stupid. It makes for dislike before they even meet you. Have your JRCNC and then put in what it is as part of the title like "CCDDGG Cat grooming".
juniorcdn
Here is what I came up with so far for my logo. I plan to put it on my vehicle and business cards when the design is finalized. I would like to incorporate a vinyl knife or Milling endmill but I am unable to find any vector images of those.
ENTDesign
Try it and look at it with the graphics added. I think you might play more with your type, also. The script looks unbalanced with the block letters.
Bill Preston
Try extending the long diameter of the ellipse a bit. Too much open space between the JR and CNC, and not enough space on either side.
Also slanted letters on an arc---or in this case following the edge of the ellipse----just don't look good. This is not just my opinion---sort of a universal truth. The letters at the left are close to being upright, and the ones to the right look as though they are about to tip over. This is true with any slanted letter following a curve, so I am not picking on you.
FWIW
bill preston
Bobby H
Arial Sucks.
I think the logo is too complicated as it is. The result is really a full blown ad and not a real logo. My own definition of "logo" is a brand mark that is reduced down to a single symbol. Ultimately, a good logo should be legible at small sizes and be able to be viewed from significant distances.
I agree with Bill's comments regarding slanted text on an arc. In general, it's not a good idea to place a script typeface on any kind of path. Script is really best set on horizontal baselines only. Text on path and envelope effects tend to work best on heavy, squared type set in all caps. You just run into problems using such effects on lots of other type.
Really, I would just try to come up with a good, technical and mechanical looking "JR CNC" brand mark -with the "JR CNC" lettering being the only type element. You can add in other advertising points, addresses, phone numbers, etc. in a full blown advertisement. I just don't think that kind of stuff needs to be placed into what is supposed to be the logo design itself. Results get too cluttered that way.
iSign
I am fully in areement with the universal truth against any slanted or italicized text to ever appear on any arc or elipse... also, somewhat in line with Bobby's suggestion against secondary copy... I would say that the text on top is not only as problem because it is slanted... but because it appears as secondary copy... but exists in the top spot. Not that one can neverr get away with that... but it just looks like it fights with the center as the first place to start reading.
I think you will want to stick with your design a long time & therefore you will want to spend a long time seeing what is the best job you can do. I suggest you sketch out 4 or 5 thumbnails in an hours time or less... if this one is still your favorite... then draw up 4 or 5 versions of this one, trying different fonts, or slight variations to shape, color, etc.
I think Bobby defines "logo" in a proper & accepted manner... but rules get broken everyday, so it's not set in stone... but my comment on not having your top line remain in the top position, could be extended to say not include it at all. You can put it on the truck, the business cards, & your signs... but get the logo nailed first...
Some of the bottom copy could remain in the logo if you want, going against Bobby's comments here, but somewhat in keeping with Marlene's comments... "Cutting 'N' Carving" could help folks understand the CNC part of the name. BTW... what is JR for? is that your nickname"
The oval can be a little boring... & it exists for what purpose? Not that you shouldn't keep it... but thre text inside does not ask for it, & no other design element uses it... maybe a ribbon could scroll over it below the main copy, adding dimension & creating a place to add the "Cutting 'N' Carving"?
Maybe the JR could be smaller... tucked up into the narrow top of the oval... & the CNC could be set in an extended font, & designed to fit center stage by itself (& defined by the copy in the scroll)
iSign
I didn't feel like taking the time to draw a good ribbon, but threw together a visual to help explain my thoughts..
juniorcdn
Doug,
I love your design. How much would it cost me to use your idea an make my logo like that? Also, what is the name of the font used for "CNC"? You truly are awesome at what you do.
Thank for all your input.
Michael
JR. CNC
Craig Sjoquist
even though doug allens design is a step in the right dierction create your own, use that as a base and do better. read mike steven's book mastering layout, that dan antonelli books 1 n 2 logo design. if all you want to do is out punch letters than don't bother, if you want to do advertising design u use what u got n go over that hump and do lot's better n use that creative ablitiy u have. the best a teacher ever said to me I won't accept till you have better than your best do it over n use what you've been taught, after turning a what I thought was my best, you know he was right the next one impressed him.
juniorcdn
I plan on still making my own. I just thought it be proper to ask to take and use his layout. Afterall, he did come up with that look which I like very much.
iSign
juniorcdn said:
How much would it cost me to use your idea...
cost? .. wel, give me 4 or 5 thumbnails of your own ideas... & then if you like this one, give me 4 or 5 redraws... & it's yours. Craig (& his old teache) are absolutely right! (oh, an thanks for the compliment :Big Laugh )
