Need help on sign for my new location
The window have solar screens on them, the sun in on this side of the building in the afternoon, I will probly take them down and tryclear focus, have to check with the city, sign ord. says only 40% of windows can be covered. maybe I can measure and use 50/50 clear focus and leave the door...
Lunatic Taskbar
If I was driving past and saw the prominently displayed word accelerated, I would probably think of car performance, not immediately signs.. Sorry.
From a distance I would have something to bring them in closer to find out what you actually do.
Your name is secondary, to being almost unimportant... what you do, how well you do it and how much is way more important than the ego of the name. Of it was Macdonalds, then yes the name will help.
Even if people are looking for you, and they see another sign shop offering what they want, belive me they will go in for a quote... so catch them as well.
IMHO
Heres a little of matt and a little of Tiki...
Marlene
how many sq ft does the city allow for your sign? It makes a big difference as you may have to figure out how to do this with less sign space available to you. I liked what Tiki did and I'd figure out a way to use the glass for the services and keep them off the main sign. When you clutter up a sign with a ton of info, you aren't doing yourself any good.
Marlene
does your last version fit into that sq footage? The services look pretty good in that one. The sign doesn't really go with it so it kind of looks like two seperate companies. If you use some Gemini type letters directly mounted to the building for the company name and use your idea for the services, it will go together better and you'll chew up less sq footage with the indiviuals letters so you can get more for the alotted sf footage.
Doyle
I definitely think that your sign should not be a rectangle. To me, the first ideas looked temporary and didn't look professional, but the later posts are on the right track. I think that the rounded rectangle looks nice, but I'm sorry, I do not like the red border below..... I think it would look better to stick with colors in your logo.... also I wouldn't stretch those letters that much, maybe use a different font?
I really like tikiboys posts, even if that blue stripe behind the main panel was a solid blue.... it would still look good.
Best of luck, please posts pictures when you complete it, and good luck at your new shop, looks nice!
Marlene
Looking much better. Not too crazy about that blue shadow as it makes it pretty hard to read but overall, it's looking good.
Take Tiki's design and fine tune it to your color liking. All the rest of them look as though you're cutting the building in half, thus creating an eye tension builder giving the viewer an unsettling amount of legibility.
dnelson
In case you aren't aware of it, Gemini DOES offer an additional discount if the sign is for your own business. Give us a call and ask about it. Makes it very affordable.
Signguyno1
For a cleaner look i also think it would look alot better over the window area
Maybe having a painted light blue bkg. On the building
Instead of having everything Square looking Maybe a Black cut out panel
With 2"foam lettering for a 3D look (ACCELERATED) white to light blue fade
and (Graphics) just all white :wink:
Best design by far. Play your cards right and the light blue stripe (or what ever color you use) will not be used in the square foot allowance for your permit.
Also if you are that far from the traveled way, you should consider a pylon, momument or pole mounted double face sign at the street.
Cadmn
Rick where are you close to in Burleson? old Movie theater, bowling alley. or are you on other end by the wally world? is Flair still out by Lowes? They used to do tons of Political signs. I was an ELK in 1977
Cadmn
I'm moving into a new location this weekend, it is on magnolia. 174 to Renfro, lt on Renfro, rt on 2nd street(Haskew) between Pawnshop and pestcontrol, 1st lt on Magnolia, 2 drive on left...
oxymo_ron
I just read through the progression of this thread, and holy crap!!! The last post compared to the first one!?!?!?! What a difference. I agree with the larger logo, and it does look better without the red.:thumb:
Kysparky
Why not use some lighting off the top of the building to give it visibility at night? Shouldn't be to expensive to give you 24 hr coverage.
