If it's old and crispy, it may break up/chip as you're scraping it off. I've had the most luck with using LOTS of soapy water and a 2" razor blade, shave away at it just an inch at a time...you can go pretty fast if you get the speed, angle, pressure right! Oddly, this will dull the blade, so be ready to change it frequently. You don't often need adhesive remover, that just makes a mess and stink! You may want to remove the 'ghosts' with a wet sponge and mild abrasive cleanser ( coment, ajax, etc.) Final prep with iso should get the surface ready.
...and WHY are there reflective numbers on glass? who's driving up to this glass? We often have people ask for reflective "...because I really want it to show up!"....when in fact there's no light source..... for the viewer to benefit from this feature!
