New connectivity issue - HELP!
TopFliteGraphics
Here since 2011
My printer decided this week it want to be rebooted after each job otherwise the job stalls before starting to print. I have changed nothing in the past week but now if I run a connectivity test on the embedded server platform, I get the attached results. I am able to print one job at a time if I reboot the printer after each job. Talk about slowing things down...
FWIW - Running Flexi and have owned the printer for 6-1/2 years always running flexi.
  • Screenshot 2025-11-02 at 08-27-04 HP Latex 315 - Connectivity troubleshooting.png
The configuration is the same as it has always been. Why would it randomly need to be reconfigured?
ISP changed subnet of enabled IPV6 & f**ked up IPV4
router decided on it's own to change ip?
i am a network consultant (40 years) and can give you a 3 page list of things that change ALL BY THEMSELVES FOR NO REASON
or it wouldn't be worth being a network consultant
Reactions: 1 users
Try going into the printer’s network settings and change the DNS address to 8.8.8.8. That forces the printer to bypass your router’s DNS relay and use Google’s DNS servers directly. Sometimes, a router firmware or security update changes how DNS requests are handled, and older devices like printers stop resolving names correctly until you point them to an external DNS server.
what are the ip's of both devices?
pc & printer
in advanced network properties on the pc are network discovery and file and print sharing checked?
microsoft likes to play with us changing settings with windows updates
is there anything in error logs for the printer?
my HP T1700dr needed a firmware update, to stop a sort of similar thing.
post those ip's and we can do a bit of testing
it may be at end of the first job the printer is not returning to "ready to print" state
