new to flexi
nightcrawler
hi all. i just had my flexi starter 8.6 starter software installed, and running a graphtec fc4100-75 cutter. im using a parralle cable, problem is when i send to cut, it does not cut right, it's just a bunch of garbage lines. the parralle cable i got is a printer cable, do i need the cable from graphtec, or is it settings somewhere that is messed up.i have no clue on what to do. am very new to this. thank's for any help i can get.
gabagoo
Major Contributor
make sure it is plugged into the paralel port and not the com port to start. You could try using a serial cable if you cant get the paralel to work....or you can try a usb to paralel converter cable although I tried that with my fc4100-130 from Signlab 8 and couldn't get it to work.
BTW welcome from Canada
nightcrawler
flexi
thank's i found the problem, i had to change the mode to epp. it's cutting now, but some letters aint cutting fully, like not completing the letter.must be more settings that need adjusting im thinking.
