Offset black type on my HP latex 315
depps74
I am experiencing a new problem. I am printing small 4" x 6" labels and posters on phototex, and getting offset print happening on the black type just the text. SEE PIC. Both black and cyan printheads look good.
balstestrat
Problem Solver
What is the print direction? Did carriage move in the text direction?
Was there something around the text like pictures or else? It's important to know.
depps74
type is horizontal so the printhead is oriented to print it left right. Put another way the printer is oriented to print it like a typewriter. There is an offwhite color in the backround and the file is an eps. Its a new problem but not a new job, been doing these types of prints for about 2 years.
balstestrat
Problem Solver
Well then it's a momentary movement error.
Did you attach to take-up? Or did you move the material by hand, did it touch the floor, end of the roll, something else? Have you cleaned the OMAS window?
If you want you can turn off OMAS and do a manual feed calibration. That should solve it.
Good suggestions...also clean the pinch rollers and main drive roller (all of it) to ensure that there are no contaminates on either surface.
depps74
ok I will try the OMAS off. HOw do I turn that off? I did clean the sensor on the print bay but not the pinch rollers, I will try that as well. I usually attach it to a 3rd party take up reel. (not HP)
depps74
what is best way to clean? Rubbing alcohol?
here are my recent alignment tests. NOt sure how to read these but they look good?
balstestrat
Problem Solver
It doesn't have anything to do with your alignment because it works most of the time.
You need to go to substrate Library and modify the print mode you are using. There is advanced settings and OMAS option to turn it off. At the same place you need to introduce advance calibration value. That test you can find in the settings under image quality maintenance.
All this stuff is also in the user guide.
If I had to guess maybe that 3rd party take up of yours gave it a good pull or something, because that sort of thing made this error happen.
depps74
ok
ok thanks. I am running my machine off a laptop. I ordered a desktop at the advice of many, but just wondering if that might be causing any of these problmems?
balstestrat
Problem Solver
No it won't cause this unless it keeps stopping during printing all the time.
Still, this is purely a material movement error.
balstestrat
Problem Solver
I still recommend the user guide to you. It's all explained there and do you know what is the best thing? It's free! No need to pay anyone.
Vacuum you can find in the same advanced settings menu I was talking about earlier.
Or when you print you have to go to the window that shows your job printing, time left etc. and there should be button to change some settings on the fly. Vacuum is one of them.
RaymondLoewy
Pretty fly for a Sign Guy
Tap the picture of the job on the display and the next screen will have a "adjustments" button, hit that and you have vacuum settings with others that can also be changed.
Christian @ 2CT Media
I'm surprised no one mentioned this yet, but what is your ink density? After printing on phototex and other fabrics for year's, that inconsistent haloing is actually the ink bleeding into the fabric. It can be solved by reducing the ink density.
Being a fabric product the fibers can draw ink into them. I bet if you print the same file and same profile on a vinyl substrate you will get different results.
depps74
how do you adjust the ink density? I am in the profile menu but those options are greyed out.
