Old Material...
KeithMan
What exactly goes bad with pressure-sensitive vinyl while sitting on a shelf? I have half a roll of perforated Oracal vinyl that is 3 years old. It has been sitting in the corner of our shop, which is kept at 72F and a humidity of 30-45%. I have read that after a year, you shouldn't use this for decals or signage, but I used it to print a sign for in-house use, and it looked great and seemed to work just like the new stuff. So my question is, what degrades, and what would you look for as far as signs of it being no good? My only real concern is that the adhesive would quit working as well and fall off, but it seems super tacky.
Boudica
One thing that happens is the surface of the vinyl can become plasticised, and looks like shit when printed.
  • Informative
punched vinyl shrinks so the spacing of the holes no longer lines up with the liner.
this failure is hard to miss
MarkSnelling
Most calendared adhesive vinyl kept in good conditions as you describe will last and perform for several years. I've had customers take cheap monomeric clearance items out of my warehouse that were 4 or 5 years old and use it for basic signage with no issues.
Perf - usually people will see the cheap perf films (monomeric) become brittle and tear/rip easily when pulling the liner off. If it is the higher end perf (3 year performers or more) you don't see it as much.
Cast - if cast sits for a long time you get an effect called mottling that puts kind of 'cloudy' spots on the vinyl. It is a result of the glossy face of the cast vinyl being pressed up to the release liner that is wrapped around it on the roll for long periods of time. It is very visible when printing. Mottling will usually self cure itself after a few days of installation, but you can get rid of it faster with a heat gun. Cast vinyl is better when stored upright to help prevent mottling a bit.
gabagoo
I have an older roll of perf as well. I tried using it about a month or so ago and one thing I can say is that it lifts off the backing paper with any amount of heat which can be dangerous for your heads. A shame that it will end up in the garbage.
