Old Screens
Kelsey Adams
Have 2 screens that have sat for over a year with the emulsion burned into them as I did use the screens. Any special or extra steps I need to do to remove the emulsion other than using emulsion stripper?
VizualVoice
I just learned how to change my title status
A little confused by your post, but if they were never exposed then you'll need to expose them (just set them out in the sun for a little bit). If they were exposed then just hit them with your remover like normal. I've reclaimed screens that were multiple years old plenty of times.
jimbug72
We reclaim multiple years old screens often enough. No extra steps, same process as a screen coated last week.
d fleming
If they have not been exposed they should wash out with water and pressure sprayer. If they have, emulsion remover and pressure washer should do the trick. If they have any ink in them that thinner will not remove or if there is a ghost image haze remover should be in the mix.
Ian Stewart-Koster
Older Greyer Brushie
If you're stuck with stubborn emulsion, caustic soda works - just watch you don't burn yourself - it's strong stinging stuff, and PPE is necessary.
