One-step away from buying a channel letter bending machine.
AndersHerp
Something, something Dark Side
I've got a guy that runs our fab shop that was here before our company got our bender (all before I started working here). He uses explicit words to describe when they use to hand bend letters, so I would say it is worth it. But I guess it really depends on how many channel letter sets you are going to make with it in a year, and are you going to end up covering your cost.
MikePro
SDS makes the best machines and bends the tightest angles/radius, but pricey as hell. We've been rocking an Accubend for a decade now and love it. The SDS can hit 3x tighter bends, but it doesn't matter much if you're just making your standard 8"+ channel letters. Feels like a little trickery to get it setup', but that's what your time with the service tech is for. Once you get the process down, and know the limitations & how to setup your files, its incalculable how much physical labor and time you'll save.
I've seen plenty of used machines out there, but you'll definitely want a tech to help you set it up and guide you through your processes.
if you do take the plunge, double-down with a clinching machine like a Norlok
Brister signs
SDS is the company that I am talking to. They are the most expensive that I have come across, but they seem to be the best when it comes to reliability and performance.
JBurton
Signtologist
Maybe you'll be lucky like me, we've had ours for 6 months and churned out 8 sets so far. It's definitely easier, but it seemed like channel letter orders dropped off the instant we had it set up. We got the cheapest accubend, it's fine, but if I had to do it again I'd go for either an old model 26 or SDS.
How does the SDS handle artwork? Do you have to buy and use a version of Enroute just to make files. That's the most annoying part to me, as my fab guy has just enough computer skills to pick the next return to run, nothing more, so artwork modifications are all on me.
mikeefly
We are currently using an Accubend Ace and are getting ready to upgrade. We will be selling our current one if you are interested.
GaSouthpaw
Our shop uses a CLN notcher and CLN bender. Does what they're supposed to do and, if you do have issues, you usually get a tech call from the owner of the company (or I did the two times I called, anyway).
rse290
We went with SDS about a year ago. Mainly use it for trimless exhibit type letters.
Have only made 1 set of actual channel letters for a building!
Once it's dialed in and you get the rout file side of it in line, everything works very nicely.
JBurton
Signtologist
This was my experience when we first bought ours. Suddenly everybody wants cabinets. Took quite a while to recall how to run the machine after that first run with the manual in hand...
We have a Varisigns letter bending machine S18 that has always worked well, we purchased it from Varibend 4 years ago and it is still running well, with no regrets about the machine or technical support. We plan on buying their handheld laser welder to replace our trimless letter Mig welder...
Bxtr
We bought an Accubend Freedom and just like said earlier once you understand the constraints of the machine and how to design for it. I was a great investment to compete with other local sign shops that had been doing them for years.
Is it the best machine out there? Probably not but we get better margins on this, plus we were already UL listed so it made sense to add this in. We also purchased a couple brakes to bend our own cabinets and retainers. It's nice not having to outsource this stuff and be on someones schedule.
Bradley D
www.jigsign.com
If anybody wants information about the SDS Automation benders, I used to be a tech for the company from 2013-2017 and then started my own company specializing in trimless channel letters since noticing that even after training most large companies were not able to produce trimless channel letters because of the greater difficulty in fabricating them. I will happily give you my take on the SDS Automation benders for standard channel letters and I am also very familiar with CLN and Accubend. My contact information can be found at: www.jigsign.com Please email me with your contact information and I will call you back.
I also own a LITE Channel Bender from SDS Automation. This model wasn't sold in the USA but is the ideal machine for what I do.
White Haus
Not a Newbie
That's some impressive work you do there with the trimless channel letters! I've always thought traditional channel letters were ugly and just looked cheap, those trimless ones are definitely a huge improvement.
