Painting Letters on a wall ..how to price
luggnut
i've got to give a quote on painting on a cinder block bldg. it is huge and they want huge letters. bldg is maybe 75ft long x 40ft tall and i'll have to cover 3/4 of it. how do you price this just on estimated time and materials or would i be cheating myself.
on a different note would you make a pounce pattern? that big i don't see how? any tips in this area would be appreciated.
HeresYourSign
I did a mural for a gym wall much like this. It ended up being about 30' wide by 5' tall. It was a nightmare trying to do it by hand. I charged time and material. Is there any way you could use a projector? I wish I would have, it would have saved time.
Jillbeans
I would project a design on that wall and sketch it on with vine charcoal.
I would snap on chalk lines to avoid distortion on the ends.
You can use a yardstick to touch up the letters after projecting to make sure they look straight.
Make sure the wall has been freshly primed and painted, with no loose danglies or bad cracks.
Can you stand on the ground to paint it? Will you be working off ladders or scaffolding? Will you have to rent scaffolding? That needs to be factored in as well.
Here's a direct quote from the 2004 Signwriter's pricing guide (so it may be worth more now) 75x40+3000 Sq. ft. (I know you said you'd be covering ¾ of it but for the sake of things we'll say 3000.)
The price guide only goes up to 400 Sq Ft....but it says $4 sq. ft. for plain one color ($15K) "Nice With Logo" is $5.50 sq ft. ($16,500)
*Labor and material is included, However, the coating of walls is not included (they say to charge 75¢/sq ft for this) and it also doesn't include scaffolding.
*The minimum charge is $346.
*Add for trip in town: $35
*Over 10 miles round trip add $1.50
*Corrugated metal walls add 50%.
I have no idea whether this helps or not. I think their prices are rather low for this type of service.
Love....Jill
Si Allen
Hmmm....3/4 of 75 X 40 = 2200 sq ft.
If it is simple text, I get $10 sq.ft., plus scaffolding or scissors lift.
Don't sell yourself short. walldogging is hard work! Also....not many guys can do this kind of work!
luggnut
here it is
this is the layout letters are a little over 4 feet tall each. and about 40 feet in length
Billct2
For the kind of money being quoted here I would seriously consider a billboard system. Then they could change it out in the future.
3dsignco
What did on a 200ft tower was the grid method as we could not get both sides of the graphic with the swing stage.
Make a scale drawing say 1" = 2ft of your building then snap chalk lines on your building then you can draw in each grid. I do it this way as I am not a good freehand artist/painter
DOGraphics
Huh?
OldPaint
iam with si, on this one. and if you have to paint a background i would add another $5 a sq ft plus paint/lift cost.
call your local HOUSE PAINTER and see what they are getting per sq ft.....on a house...and they dont have to cut in as much)))))
as for method of layout.....projection is too time comsuming, pounce pattern, unless you got 2 to 4 extra hands wont work. looks really simple lettering. i would make 2 thickness boards, one for the THICK and 1 for the THIN. work from center, out to edges....havin done this, it dont have to EXACT. and at that size i dont think anyone is goan see a 1/2=1" diff.
grid the wall, top line, bottom line of letters. lay it out, and step back and look to see it needs tweking..you can do that as you paint.
si did a roof, like this using same principal.
me and my painter freind just priced outa wall here for a deli. 10'x40 ground level. and we give the guy an estimate of $2500.00
HeresYourSign
Mural
Here is the mural I did. I freehanded this, started in the middle and used a 42" ruler. It took me close to 8 hours to get it done going up and down on a scissor lift. I would recommend using scafolding if you can and a couple extra pair of hands would be nice.
luggnut
Price?
well OP says he quotes one similar to this but didn't require a lift for 2500 and some others have said 20,000 (that was at a bigger size i over estimated) i was think 4800 for painting and lift but i have no idea. i have done painting like this before but i know i under charged and don't want to do that again. Hurts everyone in the long run.
3dsignco
Thanks Jill for the link explaining what I was trying to say
Sorry, I didn't get to finish my post or check it for errors. I had a customer come to my office and I hit post instead of the minimize button..
