PDF / Illy Issues
Angela
I am trying to place a pdf into illy for print, but once placed the PDF in illy is not what it should look like? I am not quite sure how to describe it, I am just hoping that someone out there understands what I am saying.
Angela
Please see attached, I hope I did it right.
J Hill Designs
My guess is its an issue with overprints. I dont know illy very well, but I assume there is a way to 'ignore' them on import?
Matt-Tastic
Do you know what program the PDF was made in? Any program in the world can create a PDF, so there is not really any standard in the format. If it is a PDF made from AI, there is some sort of mask on it. I doubt it's an AI PDF, however. It was probably made with something else, and its causing issues when AI tries to read it.
Bill Modzel
Essentially, you have a "negative" of your file. I've had it happen to me once before and I'm trying to remember what I did to correct it. Another sign shop sent me three files to print and only one of them printed like this.
Can you just open it in acrobat and re-save it as a new document?
MikePro
never had this happen to me, BUT if it did... i'd simply open in Adobe Acrobat Pro (or Photoshop) and save as a TIFF and then print or insert into illy for additional setup for print.
John Butto
Did you go to File/Place or did you have Illustrator opened and file/open for the .pdf. If it happens for both then what MikePro suggest might be your answer.
Angela
Indeed I tried both ways, to no avail. I am asking what program she designs in.
Angela
Just tried to open in photoshop, same thing
WI
Check your swatch palette, and see if there's not a color in the artwork that doesn't match your colorspace. What I mean is that if it's a CMYK file, see if there's an RGB swatch somewhere on the page, or vice versa. That's kind of an oddball longshot, but the last time I saw that kind of bizarro color-reversing, that was what was causing it.
